It is currently Mon Nov 23, 2026 9:13 pm
 Page 1 of 2 [ 21 posts ]  Go to page 1, 2  Next
 Post subject: a rocket engine
PostPosted: Sat Oct 07, 2006 12:12 pm
like my profile says, i have this mali wagon. i bought it with a decently tricked out olds motor in it. its got a rough idle cam that sounds like popcorn popping. new pistons and rods with a crank that was balanced when the parts were purchased and installed. so im guessing new main barrings. that was what i was told when i bought the wagon. i pulled a valve cover off and its got the gold comp cams roller rockers. other than that its stock. the rods and pistons are stock as well, just replaced. its a 6000lb car and the engine certainly pulls its weight, but its not very fast at all. if i were to guess, it runs 15's in the 1320. i also have a built 400 trans and a 4:56 10 bolt to help it on its way. the motor was put in the engine bay so he could sell me a running car. i ran the vin #'s and the info i recived was a 1968 rocket 350c.i. im thinkin it was in a 442 or something.
my question is, to an olds enthusiast, what is this iron worth the way it sits? i have no idea. i always had chevrolet to work on. i cant even find any parts for this thing. how do i get some real power out of it? i need like 400hp minimum to scoot this wagon anywhere.....anyone???
 Post subject: Re: a rocket engine
PostPosted: Sat Oct 07, 2006 9:43 pm
Hi rocket wagon, hello everyone,
like my profile says, i have this mali wagon ........
Your profile says:
Year: 1980
Make: Oldsmobile
Model: 442
Engine: 350 rocket
What is a mali?
........ i bought it with a decently tricked out olds motor in it. its got a rough idle cam that sounds like popcorn popping ........
Tricked out? What does that mean?
Popcorn popping?
........ new pistons and rods with a crank that was balanced when the parts were purchased and installed. so im guessing new main bearings ........
Receipts from the machine shop would tell you what you actually have.
........ that was what i was told when i bought the wagon ........
How well do you know that person? Did he say why he didn't make the receipts available to you?
........ i pulled a valve cover off and its got the gold comp cams roller rockers. other than that its stock. the rods and pistons are stock as well, just replaced ........
Aftermarket rockers would have been used for compatibility with the cam. They may, or may not, have been needed. They are also used to band-aid a sloppy head job.
........ its a 6000lb car and the engine certainly pulls its weight, but its not very fast at all. if i were to guess, it runs 15's in the 1320 ........
I think your guess might be optimistic.
........ i also have a built 400 trans and a 4:56 10 bolt to help it on its way ........
OK.
........ the motor was put in the engine bay so he could sell me a running car ........
Is it possible that, after he put it together, he didn't like the way it ran so, he sold it?
........ i ran the vin #'s and the info i recived was a 1968 rocket 350c.i ........ im thinkin it was in a 442 or something ........
VIN#s did not tell you it was a "rocket" and if they said 1968, they did not tell you it was a 442.
What are the numbers you used, and where did you get your information?
........ what is this iron worth the way it sits? ........
Like anything else, it's worth what someone will pay for it.
........ i have no idea. i always had chevrolet to work on ........
So far, for purposes of this thread, there is no difference.
........ i cant even find any parts for this thing ........
Any engine builder can get anything you might need.
........ how do i get some real power out of it? ........
Same as you would with a 350 Chev, increase cylinder pressures.
........ i need like 400hp minimum to scoot this wagon anywhere ........
Anywhere = Street, highway, race, or a combination.
What do you plan on doing with it? What is your budget? How much of the work will you be doing yourself?
PostPosted: Sat Oct 07, 2006 9:46 pm
Popcorn popping?
:eat:
PostPosted: Tue Oct 10, 2006 1:08 pm
Your profile says:
Year: 1980
Make: Oldsmobile
Model: 442
Engine: 350 rocket
What is a mali?
I MEANT TO SAY SIGNATURE.
1980 CHEVROLET MALIBU STATION WAGON.
WHEN I WAS FILLING THIS OUT, I WAS HAVING TROUBLE GETTING ACCEPTED FOR SOME REASON. SO I JUST PUT ANYTHING.
Popcorn popping?
TRICKED OUT, SOUPED UP, A LITTLE MORE THAN MILDLY REBUILT. AND ITS GOT THE MOST RADICAL CAM IVE REALLY EVER HEARD COMING FROM STOCK MANIFOLDS TO 3" EXHAUST WITH FLOWMASTER 40 SERIES. I KIND OF EXAGERATED WITH THE POPCORN THING, SORRY.
THIS GUY IS A LIFELONG NEIGHBOR THAT I COMMUNICATED WITH SINCE AT LEAST THE AGE OF 12. HES A LITTLE OLDER THAN I AM THOUGH. THIS PARTICULAR BLOCK HAD BEEN SITTING (on a stand) FOR A GOOD AMOUNT OF TIME, MABEY 5 YEARS. HE INTERCEPTED IT FROM SOMEONE ELSE FOR CERTAIN REASONS (not stolen) THAT I DONT WANT TO GET INTO. IT HAD ALREADY BEEN TAKEN APART, AND GONE THROUGH ITS WHOLE 9 YARDS, WHEN HE AQUIRED IT, OK?
I GOT IT BACK TO MY HOUSE AND STARTED FUCKIN AROUND CAUSE I JUST GOT THIS NEW RIDE. KNOW WHAT I MEAN? THE MOTOR RUNS LIKE A CHAMP. IVE HAD MY SHARE OF SMALL BLOCK GM's SO FAR IN MY LIFE.
IT LOOKED PRETTY COOL THE WAY IT IS SET UP. AND THE GOLD STANDS OUT.
........ its a 6000lb car and if i were to guess, it runs 15's in the 1320 ........
I DONT UNDERSTAND, YOU CHECK THE WEIGHT FOR YOURSELF, AND I THINK THAT THATS ABOUT ACCURATE. WELL, MABEY A 16.0. ITS REAL HEAVY, HEAVIER THAN AN LS1 CAMARO, BUT RUNS AWSOME!
NO, HE BOUGHT THE CAR AS A ROLLING CHASSIS. HAD TO FIND A TRANS TO GO WITH THE B.O.P. BOLT PATTERN AND JUST CHANGED THE MOUNTS EASILY. PUT IT UP FOR SALE SOON AFTER. HE WENT WITH A COUPE TO PUT HIS (A.E.S PERFORMANCE) CUSTOM PEICE OF ALUMINUM NIGHMARE IN.
HE KEPT SAYING IT WAS A "ROCKET MOTOR". I TRIED TO FIND INFO ABOUT IT CAUSE HE NEVER REALLY CARED TO LOOK FO HIMSELF. "IM THINKIN IT WAS A 442 OR SOMETHING"
I GOOGLED AND ASKED JEEVES AND ALL KINDS OF EBAY AND WHATEVER. I DONT REALLY REMEMBER WHERE EXACTLY I GOT IT, BUT IT WAS INTERNET.
THAT REALLY DOESNT ANSWER MY QUESTION. ITS JUST A DICKHEAD THING TO SAY.
WELL IT LOOKS TOTALLY DIFFERENT THAT WHAT IM USED TO.
WELL I WAS REFERING TO JEGGS AND SUMMIT. AT LEAST THEIR CATALOGS. HARDLY ANYTHING FOR OLDS UNLESS I SUBSTITUTE FOR PONTIAC OR PRETEND ITS A 455.
WELL ILL BE A SON OF A BITCH.
DUE TO THE REAR DIFFERENTIAL RATIO, I THINK ILL STICK TO THE 1/4 MILE.
I HATE BRINING MY CAR TO OTHER PEOPLE TO HAVE THEM AND WHO EVER ELSE PUT THEIR HANDS ON MY MOTOR, OR DRIVETRAIN, OR BODY OR ANYTHING. IF YOU WANT SOMETHING DONE RIGHT AND YOU KNOW WHAT YOUR DOING, THEN STICK WITH YOURS TRULY. ID LIKE TO NOT SPEND THOUSANDS, BUT GET SOME SECRET POWER OUT OF THIS OR SOMETHING. I THINK ITS AT ITS MAX BEFORE MACHINE WORK REALLY IS NECESSARY. BUT EVEN THEN I DONT THINK THIS WILL GO ANYWHERE SO ID LIKE TO STUFF A B.O.P.C. BIG BLOCK IN ITS PLACE WITH THIS TRANS AND GEAR, THEN SEE WHAT HAPPENS. MABEY A LITTLE LAUGHING GAS TO MAKE UP FOR THE WEIGHT. THE CAR IS LOCATED IN CHICAGO AT MY MOMS HOUSE. I LIVE IN WEST PALM BEACH FLORIDA. BUT THAT DONT MEAN ANYTHING, ITS A 18 HOUR DRIVE OR 5 HOUR PLANE RIDE STOPPING IN ATLANTA. I DONT HAVE MUCH MONEY NOW THAT IM HERE BUT I STILL DO HAVE A HOBBY AND JUST DOING WHAT I CAN FROM HERE. 8-)
SORRY FOR THE YELLING, I JUST USED CAPS LOCK TO DISTINGUISH WHO WAS SAYING WHAT.
i own a 1980 chevy malibu wagon with a 1968 oldsmobile 350 rocket under the hood.
PostPosted: Tue Oct 10, 2006 4:20 pm
http://www.oldsconnection.com/forum/vie ... php?t=2236
PostPosted: Tue Oct 10, 2006 5:26 pm
rocket_wagon, 88coupe is full of information. He also practices full etiquette when posting on forums, and expects the same out of who he converses with.
Dont use caps. Sounds like you're yelling.
Ask specific questions, get specific answers. I know 88coupe has the knowledge you're looking for. Be patient, it'll be worth it.
It sounds like you're more serious than most people who come around, ask the wrong questions and get frustrated (you actually took the time to reply and adress each quote).
PostPosted: Tue Oct 10, 2006 6:16 pm
I put the quote boxes in...I couldn't even read it before.
PostPosted: Tue Oct 10, 2006 8:46 pm
88delta88 wrote:
........ Sounds like you're yelling ........
More importantly, it makes it hard for many people to read.
In my case, hard enough to make me ignore the whole post.
PostPosted: Tue Oct 10, 2006 10:14 pm
Pardon the dickhead comment, but its worth whatever someone will pay...
Ebay oldsmobile and see what you find running engines for... theres a ballpark figure. "Whole 9 yards" or "tricked out" have little influence here, most of us are intrested in numbers and actual parts, not ass dyno figures.
...WELL ILL BE A SON OF A BITCH.
If you knew the answer to the question, why did you ask? Oldsmobile engines, like other internal combustion engines, are air pumps. The more air you move with the appropriate amount of fuel, the faster you're gonna go.
PostPosted: Thu Oct 12, 2006 3:32 pm
ok, im not really getting anywhere here. to everyone that replied, lets pretend that your in the market for a smallblock olds. one that is reletivly hard to find. if you were to make a pretend offer, what about would it be. so if it ever came down to it, and some asked me what am i lookin to get out of it, what should i say. like i said i did check ebay and i found nothing. didnt even really find any replacement parts. just a bunch of embalems and hood ordiments. found a set of rims that would go on an 80's style cutlass. mabey im doing a wrong search or something. but i kept getting "0 results found". mabey someone can send me a link or something.
and to 88coupe, you sent me a link to a conversation you had with someone else. either you posted it to show me that there is someone that is looking for a motor, or you wanted me to see that im not the only one that thought you were/are being a smartass. you might be full of knowledge and might have many years of experience 'with oldsmobile' under your belt. whatever. even though you feel superior to others, you could just answer there ignorant questions without quoting there entire post sentance by sentance. you could answer the ignorance with some understanding by using all that knowledge and experience that you have previously obtained.
------>regards<--------
PostPosted: Thu Oct 12, 2006 5:46 pm
200-400 bucks. Cant prove whats in it, so you cant call it a "fresh" "gone thru" "hole 9 yards" etc. For all anyone knows, there could be 2 quarts of motor honey in it so all the knocking goes away. not saying its true, but what you cant prove, you have to assume for the worst.
Ill let norm handle the rest.
PostPosted: Fri Oct 13, 2006 2:58 am
Thank you for posting something I can read.
rocket wagon wrote:
........ a smallblock olds. one that is relatively hard to find ........
What does that mean? As opposed to a small block chev?
rocket wagon wrote:
........ if you were to make a pretend offer, what about would it be ........
Hard to make an offer on something one knows nothing about.
rocket wagon wrote:
........ maybe someone can send me a link or something ........
I’m confused. Are you modifying or selling?
If you are selling, it’s not my department. I do tech here, but when I sell an engine, it has all specs the buyer could ever want or use. That includes all the balancing information, so if the buyer ever needed to replace one part, he/she would only need to balance that part, not the whole assembly.
Instead of:
rocket wagon wrote:
........ its got a rough idle cam that sounds like popcorn popping ........
I give them something like this:
Which, by the way, is the cam card for the 437 in my profile.
rocket wagon wrote:
........ you sent me a link to a conversation you had with someone else ........
And you didn’t read much of it.
calaisdriver wrote:
........ The wife said using caps was like yelling .........
That is the secondary reason. There are some people who actually have problems reading all bold, all caps, and/or no punctuation. Obviously, you are not one of them ……..
I posted it because you used caps. Had I known you were going to show the same attitude, I would have included the following.
http://www.oldsconnection.com/forum/vie ... php?t=2230
If you have any comments, feel free. It's why it's there.
rocket wagon wrote:
........ even though you feel superior to others ........
Do you know that? If so, how?
rocket wagon wrote:
........ you could just answer there ignorant questions without quoting there entire post sentence by sentence ........
You’re right, I could.
Except for adding unnecessary confusion, it would not change my questions, or answers. I prefer less confusion, so I'll stay with what works.
rocket wagon wrote:
........ you could answer the ignorance with some understanding by using all that knowledge and experience that you have previously obtained ........
We have done very well, considering you have not given us anything to work with.
You might start by rereading my post and answering the questions I asked. I did not ask them for my own amusement. I ask them to make my replies as accurate as possible.
This time, do not add anything that is not there.
Your profile says:
Year: 1980
Make: Oldsmobile
Model: 442
Engine: 350 rocket
What is a mali?
Popcorn popping?
OK.
If you choose not to use tags, just post the answers. I'll figure it out.
PostPosted: Fri Oct 13, 2006 12:26 pm
ok so, 200-400 bucks. nicely painted but not to flashy, chrome valve covers and intake. new carburator, and thats all its worth to someone that is going to assume the worst. even when they can hear it run for themselves. and mabey even drive it. sounds like to me that this thing is just as i suspected. a real heavy useless peice of shit. its prolly why nobody has them and its one of the first times ive ever seen an olds motor in a chevrolet. the thing is, now what am i gonna do with the trans? what ashame. im seriously considering selling the whole car. i have a 4 cylinder mustang that i want to have a small block chevy in. jeggs will sell me a k-member with sbc motor mounts already on them. that sounds to me a little more reasonable when it comes down to putting a motor where it doesnt really belong.
here is a link to what my car looks like. its not really much and my friend made this demo but here it is----> http://videos.streetfire.net/video/97a9 ... 1a549b.htm
i am originally from chicago, hence the music. that is where the car is located. but who cares. i wish i had more footage. or atleast a motor shot.
PostPosted: Fri Oct 13, 2006 5:47 pm
I see you are unable to post the VIN# you referenced. Does not say much for your credibility.
SBC = Small block Chev.
SBO = Small block Olds
rocket wagon wrote:
........ 200-400 bucks. nicely painted but not to flashy, chrome valve covers and intake. new carburator ........
Painted? Exterior appearance does not show what is inside, and says nothing about its condition.
What VCs, that they do not interfere with the aftermarket rockers?
Chrome intake?
Stock Carb? If not, what is it? Anyone who can read a "Jegs" catalogue is able to tell the difference.
All this, on a rebuild, done by a competent shop? If so, those receipts you were given, would show a path to its actual worth.
On a "Junque Yarde" engine? Not the first time it has been done. Hard to show any receipts for engine work in that case. Without them, it could very well be what you have.
rocket wagon wrote:
........ thats all its worth to someone that is going to assume the worst ........
Why wouldn't they. Just like a SBC, or any other make, any astute buyer would pull a head before offering more.
rocket wagon wrote:
........ even when they can hear it run for themselves. and mabey even drive it .........
It would, at least, give them some idea of its condition. Its worth would still depend on the buyers perception, after seeing/driving it.
rocket wagon wrote:
........ sounds like to me that this thing is just as i suspected. a real heavy useless peice of shit. its prolly why nobody has them ........
Interesting statement. Especially coming from one who can not understand the similarities in SBC and SBO.
rocket wagon wrote:
........ and its one of the first times ive ever seen an olds motor in a chevrolet ........
I'm impressed with your deductive reasoning.
rocket wagon wrote:
........ the thing is, now what am i gonna do with the trans? ........
Wouldn't that be your own decision?
rocket wagon wrote:
........ im seriously considering selling the whole car ........
Wasn't that the point of asking what it's worth?
rocket wagon wrote:
........ i have a 4 cylinder mustang that i want to have a small block chevy in. jeggs will sell me a k-member with sbc motor mounts already on them ........
OK. We are impressed with your extensive SBC knowledge, as well as your ability to read a Jegs catalogue.
rocket wagon wrote:
........ that sounds to me a little more reasonable when it comes down to putting a motor where it doesnt really belong ........
Your opinion, and your choice.
rocket wagon wrote:
........ here is a link ........
Looks like a "G" body station wagon. Easily, less than 4000# (with an average size driver) ready to roll.
Other than, it can do a half a$$ed "standing" burnout, what's your point?
rocket wagon wrote:
........ or at least a motor shot.
Would that show everyone what is inside it?
Would it show oversized custom pistons in a bored cylinder, or replacements in a "honed" standard bore? Same question would apply to any engine, including SBC.
If you actually desire information, post accordingly.
If you want to continue your little flame war, you can do so, by yourself.
PostPosted: Fri Oct 13, 2006 6:37 pm
rocket wagon wrote:
Went back and looked at the rest of it.
........ Other than, it can do a half a$$ed "standing" burnout ........
And, the driver(?) not being able to drive in a straight line.
........ What is your point? ........
Users browsing this forum: Google Adsense [Bot] and 19 guests
