It is currently Mon Nov 23, 2026 9:13 pm
 Page 1 of 1 [ 11 posts ]
PostPosted: Tue Oct 10, 2006 2:00 pm
I am new to this forum. What I am curious about is that when I read ANY forum, I cant seem to find any performance parts I.E. chips and such. Is there really nothing; not a web site or mfgr address?? :cry:
PostPosted: Tue Oct 10, 2006 4:23 pm
Hmm...RSM Racing used to have some parts for the aurora...seems to be gone now, Domestic Performance also used to have aurora parts...no idea what happened to them.
I'll let you know if I can think of anybody that actually still exists.
Anything specific you are looking to accomplish?
PostPosted: Tue Oct 10, 2006 6:06 pm
Thanks for touching base. What I want to accomplish(within reason), is to add some fairly quick pickup with as little hesitation as possible. I know that the engine is built very well and if formula racing uses the engine, then there are parts avail. So.....I am looking for possibly a performance chip; maybe a hotter ignition?? I need something that will at least give me about 350 horsies - naturally aspirated.
possible????
PostPosted: Tue Oct 10, 2006 8:34 pm
Hi mello, hello all,
........ if formula racing uses the engine ........
Same configuration, not the same engine. To qualify it for Indy, Olds had to make the race version available to anyone. It was available as a complete engine from any GM dealer, and it wasn't cheap.
........ I am looking for possibly a performance chip ........
Without complimentary mods, it won't make much difference.
........ maybe a hotter ignition? ........
You already have more than you need.
........ I need something that will at least give me about 350 horsies - naturally aspirated ........
Look for one of the race engines, referenced above, then detune it to your desired specs.
........ possible?
Given a big enough budget, anything is possible.
PostPosted: Fri Oct 27, 2006 12:35 pm
If you are looking to get 350 horses and keep your house then you will likely need to start with a 4.0 to 4.6 northstar engine swap. At least that way you will be starting at 300 hp instead of 250.
Keeping the costs within reason, there are not many mods for the Aurora.
K+N air filter and air box gut is usually the first step for around 12 - 15 hp.
Corsa exhaust helps alittle but more for sound than for hp as it may give you more top end, the low end torque can be reduce; low end torque is already managed by the PCM so unless the PCM is re-programed...
If you have the Autobahn Package EXPLAINED HERE that included lower gearing then you have the advantages of better off-the-line as well as the extended speed limiter to 145 mph; without Autobahn your limited to 110 mph.
Performance chips for 95s are available as the 95s are OBD-I. OBD II "chips" are not available for the Aurora but I believe a programer may be.
This web site MECHTECH uses a modified 4.0 for buggy engines with many mod options including superchargers - if you have the $$$$$
HERE you can find a few more frugle ways to improve performance a bit.
PostPosted: Sun Oct 29, 2006 9:54 pm
mello wrote:
........ I.E. chips and such ........
TJM wrote:
........ you will likely need to start with a 4.0 to 4.6 Northstar engine swap ........
Looks like more than he wants to spend.
TJM wrote:
........ K+N air filter and air box gut is usually the first step for around 12 - 15 hp ........
That much? How much from just the K&N?
TJM wrote:
........ Corsa exhaust helps a little ........
Where, at "Corsa" did you find the Aurora exhaust?
TJM wrote:
........ but more for sound than for hp ........
So, it does not give him the power he asked about, but it does give him the sound he did not ask about.
TJM wrote:
........ the low end torque can be reduced; low end torque is already managed by the PCM ........
The Computer causes a loss of power?
TJM wrote:
........ so unless the PCM is re-programed ........
The stock chip can not compensate for the "Corsa" exhaust?
TJM wrote:
........ but I believe a programer may be ........
May be?
TJM wrote:
........ This web site MECHTECH uses a modified 4.0 for buggy engines with many mod options including superchargers ........
Please post the link to the Aurora parts on that site.
TJM wrote:
........ HERE you can find a few more frugal ways to improve performance a bit.
Lots of talk about sound. Do any of them actually make more power?
PostPosted: Mon Oct 30, 2006 9:10 am
Thanks for the challanges Norm...
To my knowledge, no one (at least web-posted) has yet succesfully completed the 4.0 ==> 4.6 swap - $$ is likely the main reason, then return for investment, then lack of succesful application history combine to make the swap less than attractive.
Airbox gut how-to with pics can be seen HERE
K&N dino tests on the 4.0 Aurora application (with airbox gut) can be seen HERE
OK - so the dino shows 10 hp gains
The Corsa exhaust for the Aurora exists as a slightly modified Caddy STS system. How-to with pics and history can be seen HERE
The low end torque on the 4T80E transmission is controlled by a torque management system designed to protect the transmission. It works very well in reducing fuel and adjusting timing but web information is scarce. This is not part of the traction control system and cannot be overidden save for reprogaming.
Top end with a free flowing exhaust is improved by as much as 7-10 hp from what I have read but the low end torque tends to be reduced a bit. Overiding the torque management can negate this loss but reprograming would be required to bypass torque management.
After a little research, the programer can be found HERE
The Mechtech site has no Aurora-specific parts but it does have Northstar mods such as Supercharger Kits
It's imprtant to note that this company builds engines and systems for rail-cars and extensive modifications would be requires to adapt the products to the Aurora.
Relating to many of the links I posted previously, The Aurora Club of North America is a club that is specific to the 1st and 2nd generation Auroras. Many of our members have managed to squeeze every inch lb of power possible without getting financially burdened. We have found that there are few mid-upgrades for performance; i. e. You can spend a little ($500 - $1500) to max out what you have or go over the top at $10,000 and up. There are few options in-between.
One additional upgrade is the 80mm throttle body (up from OEM 76mm I belive). They can be had on ebay for short $$ and give a few more hp.
Tom
PostPosted: Mon Oct 30, 2006 3:56 pm
wait...they have a programmer for the 3.5L? :shock: Didn't know that...
That exhaust looks nice...looks like it should have come stock.
PostPosted: Tue Oct 31, 2006 9:53 pm
TJM wrote:
........ To my knowledge, no one (at least web-posted) has yet successfully completed the 4.0 ==> 4.6 swap ........
Then why would you suggest it?
TJM wrote:
That much? How much from just the K&N? ........
........ K&N dyno tests on the 4.0 Aurora application (with air box gut) can be seen HERE
OK - so the dyno shows 10 hp gains ........
One might expect less, in the real world.
howardm.net wrote:
........ Past 5200, no additional torque. (Ignore the Max torque reading on the upper right corner of the graph. For some reason, it seems to be using the HP graph against the torque curve.) ........
Any reason why, based on this statement, one should not question these results?
TJM wrote:
........ Corsa exhaust for the Aurora exists as a slightly modified Caddy STS system ........
Please post the quote.
TJM wrote:
........ How-to with pics and history can be seen HERE
I wonder why there are no pix of the Corsa pipe. The new pipe was custom made for that car and it did not fit. Coincidence?
TJM wrote:
........ The low end torque on the 4T80E transmission is controlled by a torque management system designed to protect the transmission. It works very well in reducing fuel and adjusting timing but web information is scarce. This is not part of the traction control system and cannot be overridden save for reprogramming ........
TJM wrote:
........ but web information is scarce ........
Now, that, is a very interesting statement.
TJM wrote:
........ Top end with a free flowing exhaust is improved by as much as 7-10 hp ........
As much as = under ideal conditions. If it is the mfrs numbers, you can expect half of that, going in.
TJM wrote:
........ but the low end torque tends to be reduced a bit ........
It should stay the same.
TJM wrote:
........ Overriding the torque management can negate this loss but reprogramming would be required to bypass torque management ........
If there was a loss, the stock comp should compensate for it.
TJM wrote:
........ After a little research, the programmer can be found HERE ........
Thank you for the courtesy of providing the link.
TJM wrote:
........ The Mechtech site has no Aurora-specific parts but it does have Northstar mods such as Supercharger Kits ........ ........ extensive modifications would be requires to adapt the products to the Aurora ........
Then why did you post the link?
TJM wrote:
........ Many of our members have managed to squeeze every inch lb of power possible without getting financially burdened ........
TJM wrote:
........ There are few options in-between ........
And you know that, for sure?
TJM wrote:
........ One additional upgrade is the 80mm throttle body (up from OEM 76mm I believe). They can be had on eBay for short $$ and give a few more hp.
Is it that easy?
PostPosted: Wed Nov 01, 2006 5:23 pm
Looking for a guinea pig
how much less do you think?
good point - 'never noticed that
sorry - HERE is the Corsa installation
I have seen nothing directly from GM describing the system but If you can find it, I would love to read it.
and your basis for that conclussion? Or is it just speculation?
you would think so right? 'something to do with the reduced back-pressure floating the exhaust valves i think. Can anyone elaborate on that?
The PCM will allow torque only to a point before the torque management software reduces power to protect the transmission- This is the way I understand how it works but I could be wrong.
Your welcome Norm
math 101
yup - I've been looking for almost 200,000 miles
Is it that easy?
yup - bolt on, done
PostPosted: Fri Nov 03, 2006 7:35 am
TJM wrote:
........ Looking for a guinea pig ........
I see you are still not able to answer a simple question about your own statement?
TJM wrote:
........ how much less do you think?
It is not stated whether any other mods were made prior to those tested. Considering the dyno was malfunctioning and none of the variables are shown on the dyno sheets, I would suspect an incompetent operator. Anything at all might be a gift.
TJM wrote:
........ never noticed that
I am not surprised.
That is a link. It is not a quote.
It is the same link you posted before. Twice.
You posted it as a citation of your statement.
There is nothing at that link that shows the validity of your statement.
I requested the quote you said was there, and you reposted the same link. Are you hiding something?
Speaking of that same link:
It is the same Corsa pipe that was custom made for this Aurora. He had to have a muffler shop finish the installation.
And it was the closest match to your statement. You did not comment on it.
This is a quote:
aurorah.proboards wrote:
........ It's quite possible you could buy a Seville system, cut your stock pipe in just the right place, and have the whole thing fit up perfectly. Or it's possible they did some other minor mods. I can't say for sure as I don't know what they did.
If you are mechanically inclined, buy it and lay it out and see. You may be lucky and it fits right up (I suspect it will). Or you may need to spend a hundred or two at a shop having them adjust it a tad ........
Is this the $1000.00 system you would recommend to the OP?
TJM wrote:
........ I have seen nothing directly from GM describing the system but If you can find it, I would love to read it ........
I said, it was in interesting statement. What did you think I said.
TJM wrote:
........ and your basis for that conclusion? Or is it just speculation? ........
Unless one meets all the conditions the mfr did, during their tests the purchaser can expect 50% or less of what was advertised. That is why the fine print and disclaimers are there.
TJM wrote:
........ something to do with the reduced back-pressure floating the exhaust valves ........
Do they use long tube headers?
TJM wrote:
........ The PCM will allow torque only to a point before the torque management software reduces power to protect the transmission ........
At a specified torque/RPM. Assuming an exhaust mod lowered the torque, the management system would bring it back up where it should be. It is why it is there.
The discussion is academic because in this case a cat back system wold not cause a power loss.
TJM wrote:
........ math 101 ........
Another of your statements you can not defend.
TJM wrote:
........ I've been looking for almost 200,000 miles ........
On the internet?
TJM wrote:
........ yup - bolt on, done[/color]
How much was your power gain?
Users browsing this forum: Google Adsense [Bot] and 19 guests
