It is currently Wed Nov 25, 2026 2:08 am
 Page 1 of 1 [ 8 posts ]
PostPosted: Thu Nov 02, 2006 4:44 pm
Hi All,
I just picked up a 93 Olds 88 (254,00 kms) for my daily driver replacement :lol: . Never owned an Olds before so I'm reading up on the brand/model. Got the car for free (some love required) so can't complain.
The car did not come with an owners manual so I'm digging all my information up online. (Eventually I'll buy the mechanics manual from Olds for this car - like I do with all my keepers - but I got to start somewhere today).
To start out; Is there a detailed breakdown online anywhere for my VIN? I'm particularly interested in knowing what each digit represents. I don't think the car has been modified but I like to use the VIN to verify what I have as a baseline.
I already used the Carfax VIN identifier to tell me that I have the following:
1993 Oldsmobile 88 Royale LS (that's what the badging tells me :wink: )
Sedan 4 Dr (Yup, its got 4 doors; if you don't include those hood and trunk thingys)
3.8 L V6 TPI (that's what the engine decals say)
Front wheel drive (not a big fan of front wheel drive)
Now I'm digging to find out what platform it is (H as far as I could determine); what engine Series (I think its a Series I L27 3800 but not postive).
I'm also interested in any information sites that would tell me things like fluid capacities; fuse panel breakdowns, etc. etc.
Once I have all of that then I'll have a pretty good baseline to order all the required maintenance parts and get this baby back into working shape in no time. :wink:
Thank You for any information in advance.
Gary
The G-Man
1991 Dodge Shadow - 4 cyl.
1984 GMC 1500 straight 6.
etc. etc.
PostPosted: Thu Nov 02, 2006 5:31 pm
Oh Yeah, I visited a number of information websites that asked me a model name and the closest choices were Delta 88 and Eighty-Eight.
Which one would my car fall into?
Thanx
Gary
The G-Man
etc. etc.
PostPosted: Thu Nov 02, 2006 5:43 pm
Another question - I'm just full them tonite.
Are the 1992, 1994 or 1995 models (engine and general car) similar to my car?
I need to know when reading FAQ's and notes which models have the same characteristics and ignore those that are different.
Thanx
The G-Man
etc. etc.
PostPosted: Sun Nov 05, 2006 7:52 pm
You've got a lot going on here....
First I'll say welcome to the site.
Then I'll answer a few of your questions that stick out....
I'd suggest making separate topics with questions that you have as they come up, that aren't answered here.
If you post your VIN...I can decode it for you. You can PM it to me if you don't feel comfortable posting it...
Yes, it is an H-Body, 1986 until its demise in 99. Yes, you have a Series I 3800.
Fluid capacities, fuse panel breakdown? The fuses and what they are should be on the fuse panel cover....but I'm sure I could dig one up if necessary.
Air Conditioning Refrigerant - R-12: 2.4LBS
Trans Fluid - Dexron II: Pan removal and replacement is 6.5 quarts, complete overhaul is 11 quarts.
Brake Fluid: top off as required
Engine Coolant - 50/50 of ehtylene glycol antifreeeze and water: 13 quarts
Engine Oil - 5W-30: 4 quarts without filter removal, 5 quarts with filter removal.
Fuel Tank: 18 gallons
Power Steering Fluid: pump only is 1 pint, complete system is 1.5 pints
Windshield washer fluid: top off as required.
In 1993, that model is named "Eighty-Eighty Royale LS"...or 88 Royale LS....although many still list it as a Delta 88....
1992-1999 they stayed pretty much the same with a few changes here and there.
PostPosted: Tue Nov 07, 2006 9:37 pm
Hi Brando,
Thank You very much for the info - it really helps a lot.
Is there another designation for the Series I I have? L27?
I'll take a peek at the fuse panel to see what it says - I know on some of my other cars you need to match up the short descriptive code on the panel with the long version in the manual - that's what I was looking for.
My VIN # is 1G3HY53L5PH301454. The 1 may be a J as I can't read my notes very well (oil on them). The original I left in the car in the shop across town.
Had a go at the car today (Brakes, Plugs, Tranny, Engine Intake gaskets, Coolant, oil) and it looks surprisingly good. It looks like the previous owners took really good car of the car. Fluids are fine, no sludge in the oil or tranny pan, spark plugs are worn but no scary suprises. The only gotcha sofar is the brake lines - they are totally gone. The car sat on a gravel driveway for 1 year - ouch. The underbody still is ok though so luckily the moisture did not get through to that - must have been undercoated.
Thanx for the advice on the posts - one per question - I'll do that in future. I am going to create one on something I have not seen before - a cylinder on the brake lines near the end...
Btw, I like your saying "no replacement for displacement" - Yup, its true. I can't believe how many pup's come to the Drag track with their 4 bangers and can't believe they were beat by a 4400lb impala. hehe :D
Gary
The G-Man
etc. etc.
PostPosted: Tue Nov 07, 2006 10:01 pm
1 = US Built
G = General Motors
3 = Oldsmobile
HY = Eighty Eight Royale LS
5 = Four Door Sedan
3 = Active (Manual) Belts with Driver Inflatable Restraint System
L = L27 3.8L V6 MFI
5 = Check Digit
P = 1993
H = Plant Code (Flint, MI)
301454 = Production Sequence Number
PostPosted: Mon Nov 13, 2006 10:25 am
Brando wrote:
1 = US Built
G = General Motors
3 = Oldsmobile
5 = Four Door Sedan
L = L27 3.8L V6 MFI
5 = Check Digit
P = 1993
Can you do the same thing for me?--My VIN is 1G3HY54C0K1832948. Thanks.
PostPosted: Mon Nov 13, 2006 1:01 pm
dblack3000 wrote:
Brando wrote:
1 = US Built
G = General Motors
3 = Oldsmobile
5 = Four Door Sedan
L = L27 3.8L V6 MFI
5 = Check Digit
P = 1993
Sure,
1 = U.S. Built
G = General Motors
3 = Oldsmobile
HY = Delta 88 Royale Brougham
5 = Four Door Sedan
4 = Automatic Belts
C = 3.8L V6 FI
0 = Check Digit
K = 1989
1 = Plant Code (Wentzville, Missouri - Wentzville Assembly)
832948 = Production Sequence Number
There ya go, if you need any RPO codes decoded, I can do that too.
