It is currently Thu Nov 19, 2026 6:27 am
Jeffs 78 Cutlass Salon
 Posted: Sun Sep 30, 2007 5:18 pm |
what is the torque spec, for the rear control arm bolts(upper and lower)
_________________ jeff wecker
abilene kansas
1989 Chevy Suburban
1978 Olds Cutlass Salon 4 door (project)
smile, you just got your doors blown off by a 4 DOOR ! ! !
BigBlockOlds
 Posted: Sun Sep 30, 2007 9:10 pm |
Torque at ride height otherwise it may put the suspension in a bind.
468/T-56/3.73
 Posted: Sun Sep 30, 2007 9:50 pm |
thanks, I will remember to wait and do it after I let it back down
abilene kansas
1989 Chevy Suburban
 Posted: Mon Oct 01, 2007 1:26 am |
BigBlockOlds wrote: Torque at ride height otherwise it may put the suspension in a bind.
Interesting advice. Did it come from the FSM?
BigBlockOlds
 Posted: Mon Oct 01, 2007 6:36 am |
88 Coupe wrote: Interesting advice. Did it come from the FSM?
I'll need to check for sure. What is an FSM? I have a CSM (Chassis Service Manual) for my '87 and an '84. I know the fronts require you to have all of the weight of the vehicle on the suspension before fulling torquing the bolts. Same with the rear if your using polyurethane (or you at least jack the rear up close to ride height).
I'll check the CSM and see what it says for sure. Its typically something I do no matter what as a precautionary measure. These converging 4 links ride like absolute crap if you put them in a bind.
468/T-56/3.73
 Posted: Mon Oct 01, 2007 8:19 am |
thanks again!!
I'll wait till I lower the car back on the ground before I torque them
abilene kansas
1989 Chevy Suburban
 Posted: Mon Oct 01, 2007 3:56 pm |
Brando wrote: Yea, the FSM (Factory Service Manual) says ........
Thanks.
 Posted: Sun Oct 14, 2007 3:23 pm |
I was just thinking, 2 of the upper control arm bolts, I noticed the nuts on them are up behind in an area that is barely accessible even with the car on blocks.
so I was wondering, would it work, if I had the weight of the rear of the car resting on jack stands?
abilene kansas
1989 Chevy Suburban
BigBlockOlds
 Posted: Sun Oct 14, 2007 6:27 pm |
According to my 1987 CSM:
Upper control arm
"Installation:
To install, reverse removal procedure. Torque nuts to specifications with car resting at normal trim height..."
Lower Control arms
"Installation:
To replace arm, reverse the removal sequence of operations. Torque arm attaching nuts to specifications with weight of the car on the rear springs."
I take this as for the uppers, you can leave the car on the jack stands but you must jack the rear end up to its approximate ride height and then torque down the bolts. Where as the lowers need to have the weight of the car rest on the ground before they are torqued.
Is this the way everyone else reads it? Although then back in the torque specs page it has an asterisk next to the control arms specs that says "Torque with weight of car on wheels"
468/T-56/3.73
 Posted: Sun Oct 14, 2007 7:24 pm |
the upper control arm bolts that attach to the axle housing, I could easily access on the ground. it is the nuts, on the other 2 upper arm bolts that I could not get to, if it were on it's wheels.
the lower arms won't be a problem to get to once it's resting on it's wheels.
abilene kansas
1989 Chevy Suburban
