It is currently Sat Nov 14, 2026 11:11 am
 Page 1 of 1 [ 12 posts ]
PostPosted: Sat Feb 07, 2004 8:20 am
Does anyone know how to tell if a Cutlass Ciera has a electronic level control system? I know it was a option on these cars (it has it listed in the owners manual also), but I dont know what RPO numbers of parts under the car, etc. I should look for to find out. :(
PostPosted: Sat Feb 07, 2004 9:14 am
you would have a compressor under the hood, and air shocks in the back. If you have shocks in the back that have small plastic tubing coming out of them, then you have it. If they're just regular shocks, then you don't.
You'd probably know it if ya had it... if you put something heavy in the back of the car, the pump should come on and "level" the car.
PostPosted: Sat Feb 07, 2004 10:10 am
Thanks :D
PostPosted: Sat Feb 07, 2004 11:30 am
Images: 12
My friends buick does that same thing, every time u get out of the car it will do it too. It's kinda cool! I've never heard of anything like that before
PostPosted: Sat Feb 07, 2004 2:15 pm
yea my mothers 93 regency 98 had that, but it stoped working correctly... and a new pump was alot of money, so she had the tubes connected to a fitting so she can raise or lower the back of the car manualy with an air compressor.
I put air shocks in the back of my 73, I like the way it looks lifted up a little in the back. Not too high though, because then it rides like a truck, :lol:
PostPosted: Sat Feb 07, 2004 6:18 pm
Images: 42
I've always wondered about that suspension. I started out with air shocks and then moved to air shocks w/ compressor/tank and manual valves it was kool!
Final 500 Alero website
PostPosted: Sun Feb 08, 2004 12:24 am
look under your hood for an air compressor... or else, look on the rear shocks, and around the rear of the car for air lines, or a level switch... It'll be pretty obvious if you origionally had it.
PostPosted: Sun Feb 08, 2004 12:56 am
I believe the air compressor should be right up front in the engine compartment....on the drivers side, right behind the headlight....
That's where I put my alarm (no longer connected), there's a little platform there....it was empty...so I put it there. But I believe that's where the air compressor goes....
PostPosted: Sun Feb 08, 2004 11:10 pm
My 86 PONTIAC 6000 STE has the compressor mounted in the rear under the trunk on the driver side of car covered by a plastic cover.
it started to develop a leak and would kick on even when just sitting there...would freak ppl out... :lol:
also had a fitting in the trunk that you could attach a air hose to to inflate things..footballs,inflatable rafts,maybe even a tire..
1988 Cutlass Ciera SC
Torque(lb-ft)-215 @ 2750 RPM
Displacement- 3802cc
4 Speed Automatic
This WAS My Dad's Oldsmobile
PostPosted: Mon Feb 09, 2004 10:04 am
my mom has a 93 pntiac transsport, and its got the level control. 6 or 7 of us would pile on to the rear, and then jump off when it pressured up... The back end would shoot up about 3 or 4 inches higher than it should, and then hiss back down to level...
its amazing what boredom will do to a person.
PostPosted: Mon Feb 09, 2004 4:33 pm
haha, don't worry I've done that too
PostPosted: Tue Feb 24, 2004 8:26 pm
Thats exactly right Brando, its right behind the Driver side headlight. I have one in my'88 88 Royale Broughm, and its not hard to tell if you have one. Everytime i disengage the ignition, about 30 seconds later it makes a loud sound of a compressor. I love that part cause it freaks everybody out.
