It is currently Wed Nov 18, 2026 6:05 am
 Page 1 of 1 [ 7 posts ]
PostPosted: Mon Mar 02, 2009 4:32 pm
im building a 67 2 door hard top, mostly a cruiser- not a racer.
330 cid
holley 600 cfm
edelbrock performer
hedman headers
3.08 one wheel peel
its originally a 2 speed but i want to hiway with this thing, go for trips etc..
whats your recommendation for trans & torque converter?
th350? th375?
PostPosted: Mon Mar 02, 2009 7:21 pm
stever wrote:
........ its originally a 2 speed ........
ST300 (Olds called it Jetaway) 1.76:1 first gear and 1:1 second, with a "variable-pitch" converter that had a high "stall" available, at the flip of a switch.
I'm happy with mine.
stever wrote:
........ but i want to hiway with this ........
Change rear gears and/or tire sizes, or go to an overdrive trans.
stever wrote:
........ th350? ........
Three speeds: 2.52:1 first, 1.52:1 second, and 1:1 third.
Same external dimensions as your ST300 and will bolt in with no driveshaft modifications. TV (kick down) cable replaces the ST300 switches, and the shift linkage must be modified.
Note: The final drive will be unchanged.
stever wrote:
........ th375?
Same trans as a TH400. Three speeds: 2.48:1 first, 1.48:1 second, and 1:1 third.
Bigger, heavier, and consumes more power. Rear cross member needs to be moved rearward by about 6 inches to fit the trans mount, shift linkage modified, needs a larger driveshaft yoke and switched power to the kick down solenoid.
Again: The final drive will be unchanged.
stever wrote:
........ whats your recommendation for trans & torque converter? ........
Since "cruising" not "racing" is your intent, you can use a TH200R4 and the "lockup" TC that it was designed to use. Should work well with your 3.08 gears and stock size tires.
4 speeds: 2.75:1 first, 1.57:1 second, 1:1 third, and 0.67:1 fourth.
Rear cross member needs to be moved rearward by about 6 inches to fit the trans mount, shift linkage modified, and a TV cable adapted to the carb.
PostPosted: Tue Mar 03, 2009 10:10 am
thanks dude, you may have won me over on the 200R4..
i had heard it was a weak transmission, not being able to handle 400 hp. i guess that was wrong information
i may not be racing it every weekend, but i wanted it to be robust enough to handle weekend abuses..
thanks again
PostPosted: Tue Mar 03, 2009 12:35 pm
stever wrote:
thanks dude ........
In my neighborhood, to call someone a "dude" is an insult.
stever wrote:
........ not being able to handle 400 hp ........
You said a stock 330. 400 HP would be an entirely different discussion.
stever wrote:
........ i wanted it to be robust enough to handle weekend abuses ........
Big difference between cruising/racing, and "abuse". A properly rebuilt 200 can handle 1000+ HP, on a drag strip, as long as it is not "abused".
PostPosted: Fri Mar 06, 2009 10:18 am
Norm, i dont live in your neck of the woods, so relax.
PostPosted: Fri Mar 06, 2009 7:33 pm
stever wrote:
stever wrote:
In my neighborhood, to call someone a "dude" is an insult ........
........ i dont live in your neck of the woods ........
........ so relax.
First you insult me by calling me a dude. Then you imply that it does not matter because you are not in my geographical area, which is insulting. Finally, you tell me to relax, which is another insult.
  1. I am not a dude.
  2. Doesn't matter where you are, you called me a dude, which is an insult.
  3. By telling me to relax, you are saying that you think I am not relaxed.
  4. To ask everyone who reads this, to believe that you are able to accurately judge my temperament, is an insult to all of us.
PostPosted: Mon Mar 09, 2009 12:53 pm
stever wrote:
........ so relax.
  1. I am not a dude.
www.youtube.com/watch?v=xgsVNMD9Ae8
I'm the dude, playing the dude- disguised as another dude!
restoring ;) photos
http://s42.photobucket.com/albums/e315/ ... on%20pics/
