It is currently Sun Nov 15, 2026 2:06 am
 Post subject: 1977 Olds Cutlass
PostPosted: Tue Apr 07, 2009 10:29 pm
OK, next question: I have decoded the VIN #, but am now trying to decode the engine casting. The # on the block, between the intake & the water pump is: 557752-3B. Any ideas? Thanks.
 Post subject: Re: 1977 Olds Cutlass
PostPosted: Thu Apr 09, 2009 10:26 pm
That should be a 77-80 350, with windowed main webs.
In terms of building an engine for power, the windowed mains are "undesirable" because the windowed blocks aren't as strong. On the other hand, they are lighter. For a semi-stock street cruiser, it will be just fine. There should be another machined pad on the block that has the VIN stamp in it- If the numbers on the pad match the VIN, it's the original engine.
