It is currently Wed Nov 11, 2026 10:52 pm
 Page 1 of 1 [ 6 posts ]
 Post subject: engine identification
PostPosted: Mon Jun 01, 2009 2:10 am
hello all...i'm a new olds owner. i got a '86 cutlass salon 442. I was told the engine was swaped out for a olds 350. the block casting # is 5577523b and it has 4a heads. can somebody tell me what the numbers mean and if it is a good block/head combo?
PostPosted: Mon Jun 01, 2009 11:47 am
Hi shortyb,
........ block casting # is 5577523b ........
http://www.oldsmobilewiki.com/index.php ... tification
........ and it has 4a heads ........
http://www.oldsmobilewiki.com/index.php ... ve_Numbers
........a good block/head combo?
Conventional internet wisdom says: A 403 head on a 350 is not a good idea. I would ask what was done to the heads/short block when the heads were changed.
Aside from the fact that, because of the engine change, it is no longer a 442, Are you unhappy with the way it runs?
PostPosted: Mon Jun 01, 2009 1:41 pm
i have only been able to drive it a few times the speedo doen't work at the moment. but i am not unhappy i think it drives pretty well. it's still kinda a 442 i do have the 4bbl carb, 4 spd, and dual exhaust.
PostPosted: Tue Jun 02, 2009 2:27 am
shortyb wrote:
........ i do have the 4bbl carb, 4 spd, and dual exhaust.
"4 barrel, 4 on the floor, and dual exhaust", applied to the W-29 option in '64 only.
PostPosted: Tue Jun 02, 2009 11:52 am
1985 to 1987 (Last of RWD 442s)
4: Four speed automatic
4: Four barrel carburetor
2: Dual exhaust
http://442.com/oldsfaq/of442.htm#442%20Meaning(s)
PostPosted: Wed Jun 03, 2009 5:32 am
442/faq is not the most reliable Oldsmobile source on the internet.
http://classicoldsmobile.com/forums/25591-post17.html
2: Dual exhaust ........
And you have cited one of the many errors that can be found on that site.
You can find the corrected data at the Oldsmobile Wiki, although it is still a "work in progress".
Oldsmobile Wiki wrote:
........ Definition of 4-4-2 from the Oldsmobile Factory Literature: 1964 (Original meaning)
    4: Four Barrel Carburetion
    4: Four On the Floor
    2: Dual Exhausts
1965 (First year of automatic transmission option on 442)
    4: 400 Cubic Inch Displacement
    2: Dual Exhausts
1965 was the last year that Oldsmobile offered a definition of 442. One can make up any fitting definition they would like for subsequent years, but there was nothing official ........
http://www.oldsmobilewiki.com/index.php ... ing.28s.29
I was not aware of that definition being used in the '65 model year. It could explain the use of the 3.975" stroke in the 400/425 engines.
