metallica_r wrote:
i was wondering if it had a dummy battery light that comes on when the battery is low.
when you first turn the key on the light should light up briefly to show you that the light works, etc. When you turn the key on do you see a light that says something like "AMP", or "ALT", or "BATT" ? I'm not a mechanic but I know that's how it usually works on alot of vehicles, I'm sure someone else will chime in to verify.
