It is currently Fri Nov 13, 2026 10:12 pm
 Posted: Thu Apr 05, 2007 8:52 pm |
Assuming you have a carb, and going by your discription only:
sean000 wrote: ........ The engine bogs down a little or hesitates a second or two and then goes. However if I step a harder on the pedal the problem goes a way and I get a smoother but obviously stronger acceleration ........ Hesitation during the transition from the cruise/economy to the acceleration/power circuit is most likely a vacuum leak. Quote: ........ Could this be a vacuum leak? ........ Yes. Quote: ........ or something else? ........ Yes Quote: ........ I have noticed the problem has slowly been getting worse ........ I would not expect it to get better. Quote: ........ I do need a new muffler (it leaks) ........ Unlikely, but possible. Since you need it anyway, replace it, and see what happens. Quote: ........ I was concerned the thermostatic valve wasn't opening when It was supposed to and I wasn't getting enough air to the carb ........
The problem is, too much air.
Does it idle at the correct speed? Have you adjusted it to get the speed right?
 Posted: Sun Apr 08, 2007 12:06 am |
sean000 wrote: ........ I do have a Rochester Dualjet carb ........ OK, first we'll check the accelerator pump. With the engine off: Remove the coil wire. Remove the top from the air filter housing. Hold the choke open and "pump the gas" while looking down, into the carb. You will be looking for 2 small streams of gas, pizzing toward the intake manifold. They should be visible at the slightest movement of the throttle valve. Check it and report back. If it checks out OK, we'll look for vacuum leaks. I'll answer your questions, in that area, as we move along, and tie any loose ends when we finish. Quote: ........ I am planning on replacing the gasket ........ First, we should find out if it's needed. Quote: ........ It is idling a little high I believe ........ Higher than it was, about 4 months ago? A tachometer or dwell/tach and a vacuum gauge will prove invaluable to anyone who wants to do their own work. Since he keeps up with the latest in tools, I will defer to andrewk in that area. Quote: ........ tuned up about 4 months ago.
Was it scheduled, or was it done to address a problem?
 Posted: Sun Apr 08, 2007 12:25 am |
Hi sean000, Norm, all-
88Coupe wrote: A tachometer or dwell/tach and a vacuum gauge will prove invaluable to anyone who wants to do their own work.
My vac/pressure gauge was purchased through Kohler small engines. I am not sure who makes it, but it wasn't cheap. A tech is required to have certain tools when they take "Master service tech" tests, and this was one of them. It was cheaper than the one off the Snap-On truck, found here.
If you have an "Arnold Motor Supply" or similar store around your area, their vac gauge will be just fine. If you don't use it often, don't spend 200 dollars on a gauge. I think I paid 90 for mine, but it came with adapters for all different Kohler engines, and I made adapters for the Briggs,Tecumesh and other engines. (A side note, when you test a small engine, it can be difficult to tap into the crankcase to get a reading. I typically take a dipstick tube and epoxy a hose barb into it near the top, and install it on the engine to obtain an access point...)
For a tach, I use one designed for small engines, but I would probably stick with an inductive timing light, which will function as a tach as well, or at least enough to set idle within 100 rpm or so. The same place you acquire the vac gauge should have a decent timing light.
Hope this helps,
 Posted: Mon Apr 09, 2007 12:34 pm |
sean000 wrote: I checked the Carburetor, and there is indeed two solid streams of fuel when I pump the gas.
I am not sure if the idle has changed from 4 months ago.
Andrewk: Thanks for the info. I will look into getting a inductive timing gun because that seems to be most beneficial to me as I can set idle and perform tune ups with the one tool. The Vacuun gauge however seems to be a little pricey for then amount I would use it.
Thanks, Sean000
I would ask at the local parts store. You could probably get one for pennies on the dollar of that high end gauge. I don't have time to research it, sorry. I linked to the snap-on one so you could get an idea of what it was, what it looked like, so that you could find one cheaper somewhere else. You could even go so far as to make a manometer, out of some tubing, a 2x4 and a yard stick, but it will be more cumbersome to use than a simple gauge.
A vac gauge is the most accurate way to set up a carb. The tool is worth every penny when you can save a hefty shop bill.
Hope this helps-
 Posted: Mon Apr 09, 2007 9:59 pm |
sean000 wrote: ........ I checked the Carburetor, and there is indeed two solid streams of fuel when I pump the gas ........ 88 Coupe wrote: ........ They should be visible at the slightest movement of the throttle valve ......... Quote: ........ I guess this could be a sign ........ Yes. Quote: ........ idle being too low?/or vacuum leak? ........ We will find out, as we continue. Quote: ........ Is this normal? ........
From your description, yes.
 Posted: Tue Apr 10, 2007 7:14 pm |
sean000,
Remove the distributor cap, visually inspect the inside and, if OK, set it aside.
Twist the rotor by hand. it should move easily and smoothly, and return to its stop in the same manner.
Remove the rotor, and inspect it visually.
Check the mechanical advance mechanism visually, while moving the weights against the springs. It should move the same as it did earlier.
Find the "vacuum advance" pot, and the vac hose leading to it. The other end will be attached to the carb.
Remove it from the carb, and (if you don't have a vacuum pump) suck on it.
You should see the vac mechanism move to its full advance position, and remain there.
If sucking on it, you will need to contain the vacuum by plugging the hose with your tongue. If not, skip this step.
If it returns home, while still under vacuum, you have a leak in the hose, or the diaphragm. You can test each, using the same method as above.
All of the above tests are part of a standard tune up.
If everything is Okey-Dokey, we will move on.
Andrew: Can a dwell meter be used on his HEI?
 Posted: Tue Apr 10, 2007 7:29 pm |
88 Coupe wrote: sean000,
Remove the distributor cap, visually inspect the inside and, if OK, set it aside. Twist the rotor by hand. it should move easily and smoothly, and return to its stop in the same manner. Norm, are you sure that you can rotate a rotor without turning the engine over? If you did move it without turning the cam, wouldn't that throw off your ignition and cam timing? Quote: Andrew: Can a dwell meter be used on his HEI?
I'm sure it could be, but the dwell angle is set permanently in the electronics of the HEI, so I don't know what good it would do. The service manual that I have says it requires no adjustment or checking, and I have read that dwell meters won't work with electronic ignition systems, but I can't verify that.
I suppose it would show us the connections being made and shut off, just like it does with points, but I think it is unnecessary.
 Posted: Tue Apr 10, 2007 8:25 pm |
andrewk wrote: ........ a simple yes would have sufficed for the dwell meter, eh? ........ Ah, but then we wouldn't have learned anything. Quote: ........ just like it does with points ........
This is the phrase that opened my eyes.
If the dwell varies, at idle, with a points dist, it indicates a bent shaft and/or worn bushings. Even though HEI has a fixed dwell normally, a bent shaft should show up on a dwell meter, right? Wrong. This would be one of my many mistakes that the clowns are unable to find. Unlike points, changing the position of a magnetic or optical trigger will not change the dwell.
 Posted: Tue Apr 10, 2007 9:45 pm |
Using a dwell meter to look at spark events would tell us exactly what is going on inside the distributor, and the version of HEI that I am assuming we are dealing with should work fine, although I have never personally hooked a dwell meter up to one.
If I recall correctly, electronic ignition came out in the mid 80's, like 85 or so. It was heavily advertised.
Regarding the rotor, how does the construction of the distributor allow this? It must have something to do with the advance, or at least thats all I can think of.
 Posted: Wed Apr 11, 2007 12:27 am |
andrewk wrote: ........ just like it does with points ........ However unintentional, you addressed the reason for my question, and the answer is probably moot. Quote: ........ If I recall correctly, electronic ignition came out in ........ HEI in '74, possibly '73 in CA. Quote: ........ It must have something to do with the advance, or at least thats all I can think of.
If centrifugal force moves the rotor ahead (20° - all in by 1200 RPM) of the dist shaft, while the engine is running, something under the cap must be moving independently of the shaft, for it to happen.
Here is an example of how it works. Looks like he sacrificed some accuracy to keep it simple.
Easier to understand if you have it in your hand.
