It is currently Tue Nov 17, 2026 6:06 am
yogis442
 Posted: Sun May 15, 2005 9:12 am |
88 Coupe wrote: Hi yogis442, all Sounds like points might be better. Less expense and no surprises.  What's a 9000 Comp? Regards, Norm
Mallory high perfomance electronic distributor. I use them on my 66 442 with Hurst/Olds 455 and my 76 Cutlass with 600hp 455. They are good performing distributors shy of needed a curbed Accel unit.
 Posted: Sun May 15, 2005 6:29 pm |
Hi yogis442, all
Quote: Mallory high perfomance electronic distributor .......... More than I need. OEM ignition with points work for me. Quote: ......... my 76 Cutlass with 600hp 455 ........
Interesting. Tell us about it.
 Posted: Sun May 15, 2005 7:51 pm |
Hi yogis442, all
Quote: Offy 360 .......... twin 750 .......... Hedman headers .......... 292 comp cam 10.5 to 1 steel pistons ........ Any headwork? Quote: 3:73 rearend gears ........ TH400 ..........
Any timesips?
 Posted: Sun May 15, 2005 8:15 pm |
Quote: some porting and machinging to allow for springs due to oversize cam.
Your cam is smaller than an OEM W-30. How did you get to 600 HP?
 Posted: Sun May 15, 2005 9:41 pm |
Quote: .......I am pretty sure I know roughly what it will do........... About as sure as you know you have 600 HP? Quote: .......... I have never had an import even show interest .......... They don't show any interest in my stock '70 350/350 Cutlass either. From your input, so far, there are several imports in my neighborhood that would be very interested, as long as you would wager on the outcome. Unless one is into high dollar street racing the only cars (import or domestic) worth racing will be found on the drag strip. Quote: .......... Left a jag behind in California ............. Same to a 69 Chevelle SS ......... Assuming all were in good condition and properly tuned, you could have been driving a stock W-30 and got better results. Quote: no time slips ..........
From my experience and the information you've posted so far, you may expect high 13 to low 14s in the mid 90s.
 Posted: Sun May 15, 2005 9:53 pm |
Quote: Mallory high perfomance electronic distributor. I use them on my 66 442 ......... and my 76 Cutlass ..........
Too bad you don't have any dyno figures to show how much HP your aftermarket stuff made over the OEM with points.
 Posted: Mon May 16, 2005 1:40 pm |
Sorry, I shouldn't have bought into your smokescreen. I don't own a W30 and I tend to forget '70 was not the only year the option was offered.
I do know how quick/fast those cars are and I stand by my statement.
Quote: ......... Shop build came back based on final info at 600hp ..........
The question has been, and still is: how you get 600 HP by adding a cam and quads to a 455?
regards, Norm
 Posted: Mon May 16, 2005 4:52 pm |
yogis442
 Posted: Mon May 16, 2005 7:52 pm |
yogis442 wrote: yeah that would be nice to get final specs on the hp. Shop build came back based on final info at 600hp. Shop is reputable and have been dealing with them for many years. As for the Jag, I don't think your W-30 would have impressed this one like you may think. Keep in mind I took it apart with a 66 442. We replaced the original 400 with 455 from a 68 Hurst/Olds. W30 350 does not have the HP rating of that 455 even from the factory. Luckily the D heads were still on the motor. It is just a fun car to drive. The 3:42 gears make it still street or hiway accessible without overloading the motor at high speeds.
As I stated, shop build came back with the HP rating based on the build, I did not. I have no reason not to believe as this shop has been building motor for both myself and brother for nearly 30 years. Smokescreen. You mean yours implying that you had a W30 car?.
Sorry, I am too old to play games with you on this. Considering you had no clue what a 9000 comp was I am suprised if you really have dealt with Olds as long as I have. Actually I get the impression you have have not even been alive as long as I have been driving these.
W30 was an option in the 68 to 71. This was primarily still on the 442 model. In 72, the 442 was soley an option on the Holiday Coupe and Cutlass convertibles. H/O was reintroduced that year. First year for 455 in 442 was 70. The big valve heads were still available. By 72 the 455 mods were done ie: emissions which greatly reduced horsepower rating from the 70 at 390 hp to a revamped formula putting it at approx 240 hp. Last year for the 455 in the design was 76. The 78 Cutlass (GM's Shrunkdown design) came with Chevy SSB. Choice of 3 motor combinations 305 4bbl, 3502bbl and 3504bbl. Only the 79 Hurst in 79 had the true Olds 350. By 81 Olds finally had there small block based on dimensions though nearly identical to the 350 the 307 was introduced. GM suffered severe set back and potential class action suit that was threatend by buyers who found out that the motor in their Olds was not an Olds motor. Funny how when people buy things they expect to get what they pay for. Early 455 which I was able obtain several year ago with the "D" heads had a great deal of hp from the factory so very little needed to be done. 66 442 is fair amt lighter than that 76. Gearing is perfect for it's use and performs just fine so very little was done. The 455 in the 76 is from a 70 as is the one I am currently installing in my 76 Buick Century Custom Wagon.
To explain for the 3rd time regarding the hp on the 76, that is what was told to me. Again I have no reason to doubt this due to rep of the shop guys who have been dealing with our motors for years. I know my brother took his couple years ago (56 BelAir) and had it dyno'd. Built 454. They told him based on the build and his aftermarket it would be in at 750hp. They actually came up a little short. Dyno recorded it at 770Hp
When he called me he was suprised as he thought with the dual Predators it would have pushed it up to 800hp. Needless to say, like me he was pleased and where we come from, long term relationships are not challenged by doubters or you lose good firends and good mechanics. Maybe something you have never experienced. For the record, I am 54yrs old. My days of racing are long gone. These are toys that will be left for my 3 sons which I based on your remarks lead me to believe all are older than you.. they come in at 27 30 & 32.
Anyway, nice chatting with you. If I ever decided to ask the guys what all is inside of that 455 I will be sure to let you know but that will be sometime from now as I have 2 more for them to build and I have no intentions of questioning them on their work. Good mechanics are hard to come by.
