It is currently Mon Nov 09, 2026 3:00 am
 Posted: Fri Oct 14, 2005 2:27 am |
Hi Brando, All,
Quote: Heat riser?
Back in the dark ages before computers, a heat riser valve was part of the exhaust system in V type engines.
A butterfly valve on one side, between the manifold and exhaust pipe, would close during cold weather warm up. The closed valve would force the gas from that bank to enter the intake manifold passage under the carb and exit thru the opposite manifold. It supplied heat to the carb and choke during cold weather warmup. Exhaust would heat a bi-metal spring that opened the valve to allow normal flow.
Most were blocked open, and/or eliminated when the original pipe was replaced.
The only ones left, are probably on 100 point restorations.
Vacuum was not involved.
EGR valve drew exhaust gas from the same under carb passage, and it was vacuum controlled.
 Posted: Fri Oct 14, 2005 2:35 am |
Intimidator68 wrote: hmmm i know that the 85 model of the 88 had heat risers not sure about 87 though. ill see if i cant find somethin out for ya. -Intimidator68
1985 is RWD, 5.0L 307 V8.
 Posted: Fri Oct 14, 2005 3:26 am |
Hi Brando, Intimidator68, All,
Quote: 1985 is RWD, 5.0L 307 V8 ........
The heat riser valve and the heat stove for the choke were eliminated in, I believe, '73 CA and '74 the other 49 States. The manifold passage was still used for EGR and carb heat, and is still called a heat riser passage, "heat riser" for short.
Don't know about the 5.0, but I believe my '87 G body/307 has one.
If I knew how to find all this stuff on the internet or in books, I wouldn't have to rely on my memory.
 Posted: Fri Oct 14, 2005 9:33 am |
I had a heat riser in my 84 caprice w/305... But newer cars with fuel injection dont use such things. The computer is capable of compensating for a cold engine using its many sensors.
I do remember though, that heat riser on my caprice was a peice of crap! I had to replace it when it rusted shut...
