TJM
 Posted: Tue Oct 31, 2006 7:53 am |
All good points Norm and even better questions. However, our somewhat personal exchange has deflected the original topic somewhat and, as I previously stated, my chemistry background is mediocre at best. Unfortunately, I am unable to elaborate any further due to that shortcoming but your points are well taken and will hopefully instill further investigation by other members of the forum.
My point, simply stated and IMHO, WD-40 liberally spayed on the undercariage provides a very good medium to attract dirt, which in turn will attract water and all the elements soluble within the water, including salt, is where the problem begins. No way I would do it.
 Posted: Tue Oct 31, 2006 10:53 am |
TJM wrote: ........ All good points Norm and even better questions ........ Thanks. In most cases, my questions are designed to help readers think for themselves, as knowledge does not come from memorizing random facts. TJM wrote: ........ our somewhat personal exchange has deflected the original topic somewhat ........ Actually, since it has been dealing with the same misconceptions the OP asked about, it is dead on. TJM wrote: ........ as I previously stated, my chemistry background is mediocre at best ........ And mine is non existent. My knowledge comes from my use of the product, not from a classroom or the Internet. TJM wrote: ........ My point, simply stated and IMHO, WD-40 liberally spayed on the undercarriage provides a very good medium to attract dirt ........ And to clarify mine: It is a solvent, not an oil. As such, it would attract no more dirt than is normally found without it. That part is, however, academic because it would evaporate, run off, be washed off, or any combination of the three, in only a few miles of winter driving. 88delta88 wrote: What kind of oil evaporates?
You, Sir, are an instigator!
TJM
 Posted: Tue Oct 31, 2006 11:29 am |
88 Coupe wrote: TJM wrote: ........ My point, simply stated and IMHO, WD-40 liberally spayed on the undercarriage provides a very good medium to attract dirt ........ And to clarify mine: It is a solvent, not an oil. As such, it would attract no more dirt than is normally found without it. That part is, however, academic because it would evaporate, run off, be washed off, or any combination of the three, in only a few miles of winter driving. Norm
Um, sorry Norm but - "Petroleum Base Oil... 30-35%" - sounds like oil to me
I'll stand by my original position - Keep that stuff away from my chassis.
On other hand - It works great for removing "permanent" marker. So, if someone were to vandalize my car all over the undeside of the chassis with permanenet marker or some nutty mechanic used permanent marker for some un-known reason under the car then I would likely use it to remove the marker and then be sure to wash it off. However, the vandal or mechaninc would have to run very fast to keep me from using the same premanent marker all over their face; unless, of course, the culprit was an atractive female in which case the ramifications would have to be reconsidered.
Tom
 Posted: Tue Oct 31, 2006 12:39 pm |
TJM wrote: ........ defined on their MSDS Sheets as Stoddard solvent with an evaporation rate of 0.1 ........ Here, you say it is solvent. TJM wrote: ........ "Petroleum Base Oil... 30-35%" - sounds like oil to me ........
Now, you are saying it is not?
If it's oil, why is it such a poor lubricant?
The tires on your car are petroleum based. Are they oil? The plastic in your car is petroleum based. Is it oil?
TJM
 Posted: Tue Oct 31, 2006 1:05 pm |
TJM wrote: Thanks for the welcome! Technically speaking, EVERYTHING evaporates at a given temperature. But I'll not go into feezing and boiling points of high-school chemistry because I never took chemistry and I feel that, with that said, it's self-explanitory. As evidence, when you spray WD-40, how long does the surface(s) stay wet? If it doesn't stay wet FOREVER then something is evaporating. WD-40 contains 45-50% Aliphatic Petroleum Distillates, defined on their MSDS Sheets as Stoddard solvent with an evaporation rate of 0.1 - whatever that means. But given that it does, in fact, have an evaporation rate, we must conclude that it does evaporate. It's true that if the surface stays oily then rust is prevented but we all know the effects/benefits of WD-40 are but temporary. Tom
Norm - you have me in stitches laughing.
Please do not "skim" my posts. Obviously, if my previous post says that 45-50% of the stuff is distillates then the remainder is something else. Subsequesnt posts include the additional information of petroleum based oil at 30-35% and the remainder, in accordence with the MSDS sheet for the product, is propellant and other unlisted non-hazardous ingredients . Had you gone to go to the links I provided in the previous post, most of your questions would have been aswered and this exchange would be exposed as an excercise in redudantcy.
Your selective omission of my text does nothing for your argument but it does stimulate the conversation.
I love good debates and I grew up with a Dad who just wanted to argue for fun. "Come on, pick a side" he would say; and off we would go.
You are not my Dad in disguise are you? Dad? Dad?... How's Mom?
 Posted: Tue Oct 31, 2006 3:20 pm |
TJM wrote: ........ you have me in stitches laughing ........ Having a little trouble keeping up? TJM wrote: ........ Please do not "skim" my posts ........ If you have a problem with my posts, go here and post your complaint. That is why it is there. TJM wrote: ........ Obviously, if my previous post says that 45-50% of the stuff is distillates then the remainder is something else. Subsequent posts include the additional information of petroleum based oil at 30-35% and the remainder, in accordance with the MSDS sheet for the product, is propellant and other unlisted non-hazardous ingredients ........ The question was, and still is: Would it be a solvent or oil? TJM wrote: ........ Had you gone to go to the links I provided in the previous post, most of your questions would have been answered and this exchange would be exposed as an exercise in redundancy ........ Would redundancy have anything to do with continuing to post the same useless link? TJM wrote: ........ Your selective omission of my text does nothing for your argument ........ And your sniveling about my posting style, does even less for yours. 88 Coupe wrote: ........ And to clarify mine: It is a solvent, not an oil.
As such, it would attract no more dirt than is normally found without it. That part is, however, academic because it would evaporate, run off, be washed off, or any combination of the three, in only a few miles of winter driving ........ Interesting that you ignored the part that deals with the actual topic, and instead posted a useless link. Remember that "red herring" I mentioned? TJM wrote: ........ You are not my Dad in disguise are you? ........
You are not DrJay or DrRansom442 in disguise are you?
 Posted: Tue Oct 31, 2006 3:26 pm |
Hi texasred,
Happy Halloween to you too.
TJM
 Posted: Tue Oct 31, 2006 3:44 pm |
Ya ya - bla bla bla. This could go on forever; and personally I have better things to do than contemplate the properties of WD-40 with my Dad for a week.
And you may want to give that link a re-read for yourself there "Stormin' Norm". Taking ideas out of context does you no justice and gives me no way to respond simply because your response makes little sense of what I have posted. But no matter, I like to play too.
Hmm - So, has nothing I have offered been of value? Or is this the typical hazing ritual of TOC. Not that I mind; It's just that I was hoping for more than the rantings of Charlie Brown's teacher.
Are we having fun yet?
 Posted: Tue Oct 31, 2006 5:14 pm |
TJM wrote: ........ Taking ideas out of context does you no justice and gives me no way to respond ........ Out of context? Did I change anything in your posts? If so, show us an example. This would be a good place. If you can not find one, we will all understand. 88 Coupe wrote: ........ The question was, and still is: Would it be a solvent or oil? ........ Still having trouble with the question? It was in response to your statement. TJM wrote: ........ sounds like oil to me ........ Or is this out of context? TJM wrote: ........ has nothing I have offered been of value? ........
Unless the answer to the above question is here or here, you you have contributed very little, if anything.
In case anyone is interested, I am more than familiar with Material Safety Data Sheets and their use.
 Posted: Tue Oct 31, 2006 8:57 pm |
88 Coupe wrote: 88delta88 wrote: What kind of oil evaporates? You, Sir, are an instigator! Norm
Well... It appears I am certainly an instigator!
 Posted: Tue Oct 31, 2006 9:48 pm |
texasred...lllloooonnnggg time no see! What's up? lol...sorry....this topic just went to hell.
Happy Halloween!
 Posted: Tue Oct 31, 2006 10:11 pm |
Brando wrote: ........ sorry....this topic just went to hell ........
Knowing his sense of humor, I suspect it was the reason he checked in.
TJM
 Posted: Wed Nov 01, 2006 2:11 pm |
88 Coupe wrote: TJM wrote: ........ has nothing I have offered been of value? ........ Unless the answer to the above question is here or here, you you have contributed very little, if anything.
Should I consider myself in good company then? Perhaps.
I concede to the fact that you have mannaged to exhausted all the information that this forum has to offer on WD-40, at least as it pertains to "undercoating".
Although your methods will take me some getting-use-to, they certainly are effective.
IMHO, WD-40 is like Razzles, first it's solvent and then its an oil.
 Posted: Wed Nov 01, 2006 6:25 pm |
TJM wrote: ........ Should I consider myself in good company then? ........ If you consider DrJay and DrRansom442 good company, yes. You have yet to quote anything useful from any of the links you posted. That goes toward defining your reluctance to post them in the first place. If I misstated any or all of the above statement, please post any quotes and sources that show anything to the contrary. TJM wrote: ........ I concede to the fact that you have managed to exhausted all the information that this forum has to offer on WD-40, at least as it pertains to "undercoating" ........ And your concession falls far short of admitting that your initial statement was based on a false premise. If I had any doubts about mine in the beginning, you have removed them with your inability to defend your own statement TJM wrote: ........ Although your methods will take me some getting-use-to, they certainly are effective ........ Asking you a direct question about your own statement? Expecting you to answer that question directly? Or both? TJM wrote: ........WD-40 is like Razzles, first it's solvent and then its an oil. So this is your only validation of the statement in question? TJM wrote: ........ Oil attracts dirt, oil evaporates and as it does, the dirt attracts water ........ And your follow up? 88 Coupe wrote: TJM wrote: ........ My point, simply stated and IMHO, WD-40 liberally spayed on the undercarriage provides a very good medium to attract dirt ........ And to clarify mine: It is a solvent, not an oil. As such, it would attract no more dirt than is normally found without it. That part is, however, academic because it would evaporate, run off, be washed off, or any combination of the three, in only a few miles of winter driving ........
With no opposition offered, I am forced to stand by this one.
