It is currently Fri Nov 06, 2026 12:23 pm
 Posted: Mon Jan 22, 2007 12:09 am |
andrewk wrote: The secondaries are blocked open ........ Yes they are. What does that tell you? Quote: ........ I may be mistaken, but is there no bolt in the rear of the carb on that side? ........ It is there. I'll post a pic. Quote: ........ I never had a carb that had that much seepage ........
I never have either, unless I bought it that way.
 Posted: Mon Jan 22, 2007 12:19 am |
GraveReaper0 wrote: ........ Could those 4 things cause what its doing? ........ They could. We will look at those possibilities as we get to them. Your manual assumes you are troubleshooting a car that has not been forked up by its previous owner. GraveReaper0 wrote: ........ And whats a CCC car?
Computer Command Control. Should be self explanatory.
GraveReaper0
 Posted: Mon Jan 22, 2007 12:25 am |
88 Coupe wrote: Your manual assumes you are troubleshooting a car that has not been forked up by its previous owner.
The previous owner was the one that did the engine swap, well his older brother did.
 Posted: Mon Jan 22, 2007 1:00 am |
GraveReaper0 wrote: ........ Now I know my idle speed is too high when its hot ........ It may or may not be. GraveReaper0 wrote: ........ and needs to be adjusted ........ Maybe. Maybe not. GraveReaper0 wrote: ........and I am having carburetor problems ........ I think we are well aware of that. GraveReaper0 wrote: ........Also my service engine light keeps going on off, but mostly stays on. I'm going to find out tomorrow what code it is ........
Wait until you are asked to do that.
EDIT: Removed some unnecessary wording.
 Posted: Mon Jan 22, 2007 1:09 am |
GraveReaper0 wrote: 88 Coupe wrote: Your manual assumes you are troubleshooting a car that has not been forked up by its previous owner. The previous owner was the one that did the engine swap, well his older brother did.
Read it again.
Your manual does not know (or care) who worked on it before. It only assumes that the car was running normally, before the problem occurred.
 Posted: Mon Jan 22, 2007 1:24 am |
andrewk wrote: ........ I would wonder what that green plug goes to ........ Solenoid that operates the power valve. Quote: ........ and if it has anything to do with the problem ........
No.
 Posted: Mon Jan 22, 2007 1:40 am |
88 Coupe wrote: andrewk wrote: The secondaries are blocked open ........ Yes they are. What does that tell you?
That they are recieving vaccum signal to open, which would tell us that the carb is hooked up incorrectly?
EDIT- Scratch that, a q-jet should have spring loaded secondary flaps, right? That means that something isnt hooked up right there, correct?
EDIT 2- Also just realized/remembered that a q-jet doesnt have vac secondaries. Boy when you dont have to tune one for a few years its amazing what can slip your mind... I better not try to ride a bicycle!
 Posted: Mon Jan 22, 2007 2:01 am |
andrewk wrote: ........ a q-jet should have spring loaded secondary flaps ........ In addition to increasing air flow, what happens when they open? Quote: ........ something isn't hooked up right there ........ Good guess. Do you think it was done on purpose? andrewk wrote: ........ a q-jet doesn't have vac secondaries ........
OK, what causes them to open?
 Posted: Mon Jan 22, 2007 4:07 am |
Here ya go.
Looks like this link works.
 Posted: Mon Jan 22, 2007 4:37 am |
GraveReaper0 wrote: ........ did the engine swap ........
Swap?
Pull the codes. We need to know if the brain is actually connected.
What was the original engine?
 Posted: Mon Jan 22, 2007 11:40 am |
88 Coupe wrote: andrewk wrote: ........ a q-jet should have spring loaded secondary flaps ........ In addition to increasing air flow, what happens when they open? More fuel, as the secondary metering rods are opening too. If they are open all the time, wouldnt this create a huge vac leak? Quote: Quote: ........ something isn't hooked up right there ........ Good guess. Do you think it was done on purpose? Well, if the pulloff isnt hooked up, wouldn't that cause the plates to not retract, but only if the spring adjustment was goofed up to begin with? I don't think anyone would do that on purpose, unless they wanted to run WOT all the time. Explains his hard starting, even without a choke properly adjusted. Quote: andrewk wrote: ........ a q-jet doesn't have vac secondaries ........ OK, what causes them to open?
What I meant to type was that they arent vac secondaries like a holley. IIRC, a holley responds to venturi vac, not manifold. Q-jets use an air valve but that is actuated by manifold vac, right? Supposed to be a seamless transition... I think I need to buy that book and read it... I don't know as much about this as I thought I did.
 Posted: Mon Jan 22, 2007 3:38 pm |
GraveReaper0 wrote: ........ The original was also a 307.
Thank you.
Your use of the word "swap" is a subject for a different thread.
Now, open and close both doors by hand, to see if they move freely.
 Posted: Mon Jan 22, 2007 4:57 pm |
andrewk wrote: ........ If they are open all the time, wouldn't this create a huge vac leak? ........ Fuel leak,yes. Vac leak, no. andrewk wrote: ........ if the pull off isn't hooked up, wouldn't that cause the plates to not retract, but only if the spring adjustment was goofed up to begin with? ........ We can continue this one after he shows us the right side of his carb. Quote: ........ unless they wanted to run WOT all the time ........ Or unless they had no clue what they were doing? Quote: ........Explains his hard starting, even without a choke properly adjusted ........ Part of it, anyway. Looks like the choke was opened on purpose, in order to "band-aid" an already rich mixture. Possible, the air valve was opened for the same reason. Hard to second guess a bull in a china shop. Quote: ........ they aren't vac secondaries like a Holley ........ Apples and oranges. Vacuum is vacuum. Quote: ........ Supposed to be a seamless transition ........ It is. Only one of the reasons it is the best carb for the street. Quote: ........ I don't know as much about this as I thought I did.
You haven't asked yourself enough questions.
