It is currently Sat Nov 14, 2026 9:21 pm
 Page 2 of 2 [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: Engine Problems
PostPosted: Wed Mar 07, 2007 2:41 pm
........ We were told that the sock is in bad shape and go bad anytime ........
Since, in your case, the pump would have had to be removed, in order to into inspect/test the sock, I wonder how that conclusion was reached.
Before "in tank" fuel pumps, a quick fix was to use air pressure to blow the sock off the pickup tube. No sock, no problem. Yours is in the tank, so the sock cannot be addressed unless the pump is out. Easy to change it, at that point.
........ We were also told the gas pump was in need of repair ........
A simple pressure test will verify it's condition. If it was done correctly, you need a new pump. If it was not, there is no way to know it's condition.
........ but in order to repair we need to replace the whole gas tank.
Replaced, as with another tank or replaced, as reinstalled the same one? Since the tank has to be removed, in order to access the pump, it looks like a possible misunderstanding.
........ Do you think my fuel pump is giving me problems?
It's only one of many possibilities.
GraveReaper0 wrote:
Sounds to me like you need to be looking for a new car.
Another, of many thoughtless posts by TOCs resident Clown.
chesleeb wrote:
Are you serious? ........
We do not know whether he is, or is not. We do know, however, that he knows nothing about the topic.
Our apologies, for not being able to warn you ahead of time.
........ Could a bad sock or fuel filter/pump cause your car to jerk, shut off, and make it hard for you accelerate?
Filter will show slightly different symptoms that would have started at higher speeds. Clogged sock (primary filter) would show the same symptoms, but it is rare for one to get that restricted.
Check the filter, change it if necessary, then have the fuel pressure tested before you go any further.
PostPosted: Wed Mar 07, 2007 2:58 pm
Dude, that car is shot! Bad fuel delivery, shot exhaust. Junk it and get a vista cruiser with a BIG OL 455!!!! :twisted: :twisted:
And whatever you do don't listen to Coupe. he don't know his head from his ass.
PostPosted: Wed Mar 07, 2007 3:36 pm
GraveReaper0 wrote:
Dude ........
And again, he proves to the world that he cannot keep up with the rest of us.
PostPosted: Wed Mar 07, 2007 4:45 pm
GraveReaper0 wrote:
Dude ........
Aww, I know you can do better then that, whats a matter, ran outta ideas to insult me?
PostPosted: Wed Mar 07, 2007 5:50 pm
GraveReaper0 wrote:
Dude ........
When you finally catch on, let us know.
I am finished with your thread hijack.
PostPosted: Wed Mar 07, 2007 7:50 pm
GraveReaper0 wrote:
Dude ........
Oh please, be a man a take your blame, you started it. And don't be quoting my first post, because it wasnt for you.
PostPosted: Thu Mar 08, 2007 10:14 am
I faintly hear the sound of a toilet flush. It must have been this thread.
Do you seriously think you've contributed in any way to this nice lady's simple problem? By suggesting a fuel efficient 3.8l should be junked for a car twice the size, and double the displacement to haul around children?
Maybe there is a method to the madness?
PostPosted: Thu Mar 08, 2007 12:18 pm
Just to keep you guys updated I took it in an the mechanic did a diagnostic and no codes came up, it drove great yesturday no problems. The guy looked at my MAF sensor and the wire things were dirty so he cleaned them he looked at my fuel pressure and etc... everything he said looked okay for now. The only concern he had was for my radiator it needs to be replaced or flushed there is a lot of junk inside so i might just replace it, he also said i should replace my fuel filter. I drove it around after he was done and it does drive a lot better. The guy was so nice he didn't even charge me. My question guys is what can i do in order for me to get gas at other gas stations ? Oh yeah he told me my tank was damaged. I knew that. How much does it cost to replace them, does it come with a fuel pump too? Is it best to get a brand new one or a used one?
94 88 Delta Royal 116,000,
PostPosted: Fri Mar 09, 2007 12:08 am
chesleeb wrote:
........ what can i do in order for me to get gas at other gas stations? ........
The "brand" should not be relevant. I think your belief, that it is, is based on coincidence.
........ does it come with a fuel pump too? ........
No. Normally you would use your existing pump.
........ Is it best to get a brand new one or a used one?
Not a "wear item". A used tank will work just fine.
PostPosted: Fri Mar 09, 2007 4:34 am
Its a lady??
PostPosted: Fri Mar 09, 2007 7:37 am
GraveReaper0 wrote:
Its a lady??
chesleeb wrote:
It was the idler pulley my husband replaced it today! So hopefully everything will work out ok.
odds are it's a lady :lol:
unless it's.... uhh..... 8-[
PostPosted: Fri Mar 09, 2007 2:55 pm
Everyone:
How about a big round of applause.
GraveReaper0 wrote:
GraveReaper0 wrote:
Dude ........
When you finally catch on, let us know ........
Its a lady?
Let's hear it for GraveReaper0.
PostPosted: Tue Mar 13, 2007 5:33 am
=D> =D> =D> :laughing: :laughing: :wacko: ](*,)
PostPosted: Tue Mar 13, 2007 12:21 pm
Where's the beer?? :drunk: :drunk: :eat: :drunk:
PostPosted: Tue Mar 13, 2007 12:53 pm
GraveReaper0 wrote:
Where's the beer??
All over the road down the street from here ;-) The beer truck had a classic mishap a few weeks ago just a few blocks from here.
Driver either forgot to close, or the sliding back door didnt latch. He accellerated away from a light, turning the corner, and I am not shitting you, at least 10 - 20 cases of various beer (in bottles) landed on the pavement. When I saw it, they had the police blocking the area off for cleanup... I imagine they would have had better luck getting 10 eager guys with straws out there ;-).
You hear about things like this on the internet, but never get to see them in real life. Wish I'd have had my camera.
