It is currently Fri Nov 20, 2026 6:07 am
86Delta
 Posted: Sun Jan 11, 2004 5:12 pm |
i think Napa batteries are made by Excide. they are junk too.
 Posted: Sun Jan 11, 2004 5:17 pm |
86Delta wrote: i think Napa batteries are made by Excide. they are junk too.
My Napa Legend Battery hasn't been too bad actually....
Cept for when I had to recharge cause I hadn't started the car in quite a while...at least a week
I think they changed who manufacturers their batteries...I forgot what they changed to though....
86Delta
 Posted: Sun Jan 11, 2004 5:26 pm |
having to jump start a car after not being started for a week is not normal. the plow truck at the shop sat all summer and fired right up this winter with a little spray of carb cleaner in the carb. of course it doesn't take all that much juice to turn over a flat head 6 cylinder in a 62 Willy's pickup.
73Delta88
 Posted: Sun Jan 11, 2004 7:15 pm |
86Delta wrote: having to jump start a car after not being started for a week is not normal.
no, it's not... unless there is some sort of constant draw. Didn't you say that something from your stereo is constantly drawing power Brando?
 Posted: Sun Jan 11, 2004 8:05 pm |
No...there's absolutely no constant draw on my battery except for the stereo holding it's time and presets...and yea...that's it...I am seriously thinking of doing a major upgrade on my electrical system.
I'll have to see if I'll have enough money left over...I might need to sell some more of my stuff
Rockford Fosgate 5 Channel Amp...2 MTX 12" 4000 Subs in a Sealed Enclosure....those are the best things I have...I'll have to see if there's any buyers around.
strokercutlass
 Posted: Fri Jan 16, 2004 8:50 pm |
| TOC Mechanic |
hard to say if they're related....did you ever have the battery load tested, like was mentioned previously? Swing by an auto parts store and have them check it for you...if the battery tests out ok, I'd suspect the starter possibly having a short in the armature (sp), even if its not that old....that would cause a significant drain on the battery, but would turn the car over, but very slow, as you said....
