It is currently Sat Nov 14, 2026 11:28 pm
 Page 2 of 2 [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Rear View Mirror...
PostPosted: Tue May 29, 2007 12:53 am
This just came to mind....
How would you remove the mirror?
:lol:
Pretty much impossible to get to the tab.....
PostPosted: Tue May 29, 2007 1:32 am
Brando wrote:
........ Says the support just pops out with a flat blade tool ........
Easier and quicker to remove, than the torx that was used earlier.
........ One person pushes down on the spring clip, where the red is pointing ........
The red is pointing to the space between the 2 legs of the clip. The white is pointing to one leg. A slight pressure on both legs, is all it takes to release the tension on the retainer clip, and the mirror assembly can be lifted off the support with the other hand.
Since, in this case, the mirror was already off, the support would have been removed with a finger on the other hand.
........ The other person ........
Should have been opening 2 beers, so they could celebrate a job well done.
PostPosted: Tue May 29, 2007 2:09 am
Slight pressure? I was putting all my weight on that thing....it finally budged enough for it to slide out....that's what the table was for....to support my weight pretty much... :lol:
PostPosted: Tue May 29, 2007 3:03 am
Found the tool that allows you to remove the mirror, when it is still mounted to the windshield...
http://equalizer.com/mm5/merchant.mvc?S ... y_Code=12i
PostPosted: Tue May 29, 2007 5:15 am
Brando wrote:
........ I was putting all my weight on that thing ........
You must not have been holding your tongue right.
PostPosted: Tue May 29, 2007 4:28 pm
Yea, forgot to twitch my nose and blink twice too! :doh:
The tab is mounted....that stuff sure does set quick....gonna let it cure for a while....says you can mount the mirror in fifteen minutes, but I think I'll wait.
Used this:
NAPA Part # 7651184
That picture shows Loctite, mine said Permatex on it. Same company apparently.
PostPosted: Wed May 30, 2007 6:28 pm
I have a mirror again, installation was pretty easy.
And I just realized, the service manual was telling me how to remove the support while it is still on the windshield... :doh:
PostPosted: Thu May 31, 2007 1:09 am
........ Since, in this case, the mirror was already off ........
Users browsing this forum: No registered users and 20 guests
