It is currently Tue Nov 24, 2026 6:26 am
 Page 2 of 3 [ 31 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Bad TPS?
PostPosted: Thu Sep 27, 2007 8:45 pm
91buickman wrote:
thats why i told you from the jump to get your ICM module tested ........
Classic example of an "I told you so".
91buickman wrote:
I never said i told you so ........
Classic example of "Backpedaling".
91buickman wrote:
........ When i had mmy engine cleaned along time ago ........
Read the following, again.
........ your situation is not the same as mine ........
He only repeated what you have already been told, several times.
Here it is, again:
With one exception, the symptoms another car may, or may not show, does not alter the troubleshooting process.
The exception is: If, all symptoms, of two identical vehicles, are the same.
It is what every participant, in any automotive forum, should already be aware of.
PostPosted: Thu Sep 27, 2007 9:32 pm
91buickman wrote:
ICM is probably screwed--have it tested ........
If the symptoms pointed to the ICM, it would, indeed, be the first suspect.
However: The ignition control reads data, from the sensors, at startup. After a few seconds, it switches control (except spark advance) to powertrain control.
Symptoms (No advance = no power and a small stumble, under certain circumstances) of a dead ICM, are not the same as those andrewk described, so it might be the last place to look.
Again, it seems, 91buickman's Buick is not subject to the same laws of physics, as every other GM car.
PostPosted: Fri Sep 28, 2007 9:05 am
Nobody ever suspects the module itself they always think its the coils but oh well.............
Exactly but if the ICM is screwed on any circut, the ECM wouldnt be able to read and the ICM is not capable of running the engine so.....thats why i said ICM....from the start
Uh in a distrubotur equiped car but not not in andrews case as he has no distributor, There is no refrence for the ecm to use if the ICM is screwed, Therefore IMO its always suspect.
Physics-----Ignition control module------relevance??----diversions
[/quote]
PostPosted: Fri Sep 28, 2007 2:18 pm
I'm sorry, did I miss where this thread moved from diagnosing a problem to what you think people suspect? Your diversions are not helping the site, and it is getting tiresome. Either stay on topic, or don't post.
This is from 60degreev6.com- I don't know how factual it is, but I will check with my mechanic to see what he says- That site seems to be mostly OBDII stuff, so I don't know if OBD I is different, or not.
Also referred to as part of the Distributorless Ignition System (DIS). The ICM is the flat plate that the coils plug into and the ICM controls which coil is fired when, it is an independent system from the ECM. Through the CPS that is hooked to it it determins which coil to fire and sends a rpm/reference to the ECM so that the ECM can monitor engine speed. Below 400rpm the ICM controls spark advance by triggering the 3 coils at pre-determined intervals, above 400rpm the ECM will tell the ICM how much to advance the spark. It is a fairly decent and simple piggy back system that works quite well.
There are many other things, that could cause the engine not to start. My original post was very clear that it was an unknown problem. The guess of ICM was a stab in the dark, and another tally mark to add to your list of BS posts.
No its not. The car could run with a bad ICM.
I read it as topical humor, and it did not avert attention away from the subject of the thread, unlike your constant off-topic posts.
PostPosted: Fri Sep 28, 2007 2:29 pm
Alright- I got it figured out.
The spark problem was a poor connection to the ICM. That was fixed, car still did not fire, but had great spark. Checked fuel pressure again, was right at 45psi. I unplugged an injector, and put a test node in the plug, and tried to start it. I had great pressure, but I lost pulse. I found an injector with a short, and one that is weak.
I honestly didn't think that it was going to be injectors, but the guy letting me use his shop told me that early 3.1's will not fire the other injectors if one is shorted.
I have more to post, will post later-
PostPosted: Fri Sep 28, 2007 10:15 pm
uh if you read your buddy was the one who said suspect first, if thats off topic, then so is your buddy but we all know how you get down....
READ again...
The guess of it being a TPS sensor was no more a stab in the dark then the ICM, Count another tally on your hypocrite board.
yea so what you posted above was...."Below 400rpm the ICM controls spark advance by triggering the 3 coils at pre-determined intervals, above 400rpm the ECM will tell the ICM how much to advance the spark.".......so if the ICM is bad the ECM cant control anything meaning it wont run....
post the quote where i was off topic on this, besides resonding to you and your buddies crap.........[/quote]
PostPosted: Fri Sep 28, 2007 10:34 pm
No problem.
91parkave wrote:
when the people pressure washed my engine before it took out the starter solenoid which caused it ti short when starting up, which in turn grounded out to the ICM and fried it.
Had nothing to do with my situation then, and it doesn't now.
Here is what Norm said.
If, meaning if they did, but they did not. You can stop with the childish finger-pointing now.
It is capable of running without the ECM. The crank sensor is what sends the signal to the ICM, and it can, and does run without the ECM.
Quit acting like a child, or quit posting. I don't care what you choose, but do one or the other.
Since I said in the original post-
Intermittently, when I push down about half way on the gas pedal, the car lurches, sputters, cuts out, or sometimes just dies. It also dies when I start it, but eventually it will start and run. If I leave it out of gear, I can rev it all I want. However if I press quickly on the gas pedal, it will cut out when out of gear.
It acted up when the accelerator was in a specific position. The logical person would test the TPS, as I did, for any abnormality, seeing as it is what reads throttle position.
The statement of "your ICM is probably screwed" is based on no data that you have about my car. Grow up.
It will run, but it will trip a code. It probably wouldn't run good, but it would be a consistent problem, not an intermittent one.
PostPosted: Sat Sep 29, 2007 12:16 am
To clarify: ICM controls spark advance. Any conventional engine will start, and run, using only initial advance.
The following applies, whether there is a distributor or computer, or not:
When the RPM increase, and the advance does not, there will be a noticeable power loss. It will be accompanied by a small stumble during the transition, from no load, to load conditions.
Source: Los Angeles City School District, third week, first year High School auto shop.
PostPosted: Sat Sep 29, 2007 3:41 pm
Hi all,
In the interest of clarity and accurate discussion about the early 3.1, it has occurred to me that the early 3.1 is not equipped with an ICM, but an IDI module. This performs the same task as the ICM, but it is different than the ICM that we have been referring to, if only by name.
I am confused. After reading my manual some (haven't had a chance to get to my car again, the owner of the shop is gone for the weekend) it says the following about the IDI module:
Chilton W-body manual wrote:
The EST system, used on 1988-92 models, includes the following circuts:
The EST system is basically the same EST to ECM circuit used on the distributor type ignition systems with EST. This system includes the following circuits:
Reference circuit (CKT 430) - provides the ECM with rpm and crankshaft position information from the IDI (edit - which means integrated direct ignition, which would be the equivalent of the ICM) module. The IDI module receives this signal from the crank sensor.
Bypass signal (CKT 424) - Above 700 rpm, the ECM applies 5 volts to this circuit to switch spark timing control from the IDI module to the ECM.
EST signal (CKT42) - reference signal is sent to the ECM via the DIS module during cranking. Under 700 rpm, the IDI module controls the ignition timing. Above 700 rpm, the ECM applies 5 volts to the bypass line to switch the timing to the ECM control.
Reference ground circuit (CKT 45) - this wire is grounded through the module and insures that the ground circuit has no voltage drop between the ignition module and the ECM, which could affect performance.
Aside from the edit, that is verbatim, and it is somewhat repetitive.
The way I understand it from my manual, is that it is the ECM that generates the signal to tell the IDI module when to fire. The IDI module is what actually gives the coil impulse to fire, but without the ECM, there would be no advance.
Norm, can you please clarify? Am I missing something?
Either way, had my car been experiencing a no advance situation, it wouldn't have cut out and died, it would have experienced power loss and stumble, neither of which happened.
PostPosted: Sun Sep 30, 2007 2:46 am
........ Bypass signal - Above 700 rpm, the ECM applies 5 volts to this circuit to switch spark timing control from the IDI module to the ECM ........
If there is a ground (short) or open in the circuit, the transfer will not take place and the advance will remain static. Pretty much the same as the distributor in my 307.
If the transfer does take place, yes, the comp uses data from the ICM/IDI to control spark timing. Pretty much the same as the distributor in my 307.
Looks like I had it backward. I sure hope that doesn't become a habit. I would never be able to live with the constant ridicule.
Which reminds me: Are you sure you have a 3 coil system, not a distributor? Would 91buickman lie to me?
........ Either way ........ neither of which happened.
And that was my point.
PostPosted: Sun Sep 30, 2007 10:37 am
Thanks for the clarification Norm. Since my manual (I know I called it a FSM) is not made by GM, you never know what misinformation lies within-
:lol: :lol:
Yes I am.
He would have to have an idea of what he is talking about first- :lol:
PostPosted: Sun Sep 30, 2007 3:16 pm
1. Explain how i dont know what im talking about by telling you to test the ICM.
2. Exaplain How im chilidish for telling you to do so
PostPosted: Sun Sep 30, 2007 3:33 pm
The use of fonts is unnecessary, as I can read what you say, when you spell it right.
91parkave wrote:
ICM is probably screwed--have it tested,
And here is your justification, or reasoning for me to have it tested.
Did I say anything about my starter? How does that reasoning apply to my situation?
The answer to both of those, is no.
Have you given BS advice and information on this, and other boards previously? The answer to that is yes. Did any of your following replies have anything to do with my problem? The answer to that is no. I can only conclude, through experience and deductive reasoning that you don't have a clue about what was wrong with my car.
But maybe I just "factual" data...
After your initial reply- you follow with this-
How does your initial reply have anything to do with why I thought I might have a bad IDI module? That's childish reply #1.
Here is reply # 2 that has nothing to do with this thread-
91parkave wrote:
II never said i told you so...please my comment was far from that, if you ttok it that way \, its on you, now onto the situation at hand. When i had mmy engine cleaned along time ago water must have worked its way into the solenoid and it would click click and then turn over, and then my engine stopped running i have videos of it as well, anyways i snatched the starter off had it tested it blew the breaker on the machine at autozone. After i replaced the starter same shit with the engine but no click anymore, after tesing i concluded the ICM, swapped it and it fired right up no problems, which is why i mentioned the ICM to you because i assumed you already tested everything quit being so sensitive as you would say to me.
A child is a person that is very young, and since they are young, they have little understanding about the world around them. They are not able to make rational decisions, or use logic very well. Your correlation of wet engine= bad ICM is not only a poor diagnosis, but it is childish. You fail to recognize that engines are different in many ways, and conditions between 2 engines hundreds of miles apart will be different, and can lead to different types of failures that are different from what you have experienced.
Its like seeing trees, but not the forest.
PostPosted: Sun Sep 30, 2007 10:40 pm
No.1 Exactly what im saying, let me tell you AGAIN maybe you will catch on, Since both of us had our engines pressure washed....I thought i would share what happen with me and possibilites of what COULD BE WRONG!! I
never told you to replace anything just have them tested....that simple but yet im childish and know nothing because i was trying to help your ass out to help elimanate other loose ends that might not have came across to you, i cant see why you have to act a ass about it but its on you take it for whats its worth but do not make claims about me just because you wana throw a b%^* fit.
PostPosted: Sun Sep 30, 2007 11:07 pm
I initially wasn't going to reply to this, since there is little substance here, but what the hell, I'm bored.
Again, use of fonts and caps are
UNNECESSARY as I can read through the poor spelling and grammar to see what you are saying.
Let me tell you again why I displaced your experience and prior situation. Maybe then YOU will catch on. If water were to short out my IDI module, it would have done it right away. I wouldn't have driven it the long distances I did and still have it perform well. If it was wet, it would have shorted out fast, and 2 plus hours of driving is going to dry everything out.
The reason I suspected the TPS sensor was because it was dependent, at least at first, on the position of the accelerator. A simple test displaced that theory right away.
91parkave wrote:
I never told you to replace anything just have them tested....that simple
If you have an electrical problem, you never just pull things and test them, you locate the problem first, systematically. Anyone that deals with electrical problems on a constant basis knows this. It could have been anything, a bad connection, open wire, shorted wire, etc, etc. If you start removing and replacing parts, you are destroying the evidence. You could alter a connection enough to get it to run, but not fix the problem.
Leave my ass out of it. It doesn't like help, as it is a one-way street down there, which is exit-only.
When you reply like you do, you are acting immature, like a child. Sorry if you don't like the reflection in the mirror, but nobody here can be responsible for what you type.
I appreciate the attempt, but it did not apply to me.
The use of ":roll:" was to indicate sarcasm, not seriousness. That was supposed to be funny, not a flame. I was very nice in telling you that your reply did not help me when I posted this-
Besides that, your situation is not the same as mine, my starter solenoid works fine, and I would be interested to see how a pressure washer can short that out in the way you describe. The pressure washing of the engine may or may have nothing to do with my problem, and if it is the cause, it could have shorted out any one of a number of electronic components that are not the ignition module.
I did, and I told you what I thought of it in a professional manner.
If you had been posting relevant, reliable information lately, I never would have said a word. What's on you is the content of your posts. If they are crap, how can I assume any different about your knowledge? It's a claim based on experience with your posts, no more, no less.
