It is currently Tue Nov 24, 2026 6:13 am
 Page 2 of 2 [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Sat Dec 22, 2007 11:25 am
Well it seems that my upper intake is going south. When I did a head gasket 20K ago, I had to replace the upper intake manifold. If I remember correctly, the one the junkyard sent was slightly different, but bolted up. I actually had to tear the thing down one more time before final assembly, so theoreticaly I should have replaced the intake seals yet again.(new ones were installed, then removed again) I was at the end of my rope financially and I didn't really expect the car to run anyway, hence the omission.(poor excuse, I know :blush: )
In short, I have been losing coolant into the engine, and the telltale milky oilcap is present. It's obvious that I will need to replace the gaskets. My question is this. Should I install a new OEM manifold in addition to new seals? I have found Genuine GM manifolds online for $196.
The seals are also very reasonable.
http://www.gmpartsdirect.com/catalog/frameset.cfm
If anybody had experience with this company I'd be curious if the service is as good as the prices.
PostPosted: Sat Dec 22, 2007 11:52 am
you'd be getting ripped off big time the OEM design has known flaws the biggest is the EGR runs directly into the passage where the coolant runs, over time causing warpage and your current problem you have now----the aftermarket replacments are what you should go for http://www.zzperformance.com/grand_prix ... &catid=113 is perfect for that application you have- there are other things like pluging the coolant holes in the LIM but you can PM me for the rest of the details..
PostPosted: Sat Dec 22, 2007 11:56 am
Thanks!
PostPosted: Sat Dec 22, 2007 12:49 pm
http://www.automotivepartsnetwork.com/s ... uct=229679
PostPosted: Sat Dec 22, 2007 1:25 pm
http://www.automotivepartsnetwork.com/store/pc/viewPrd.asp?idproduct=229679
Since this design includes the PCV with improvements does it install with less modification than the one noted above?
Thanks,
Jon
PostPosted: Sat Dec 22, 2007 4:07 pm
myfathersoldsmobile wrote:
........ does it install with less modification than the one noted above?
That “mod” is a joke.
While you have it apart, change the lower intake gaskets also. GM sells a set, with aluminum frames, for about $60. Buy it and use it.
Most important thing, is to follow your Factory Service Manual, to the letter.
PostPosted: Sat Dec 22, 2007 7:29 pm
The manifold you mention can be ordered with its own gasket set. I assume that doesn't include the lowers? When I go to GM parts direct, they only have one gasket listed, the main one. GMpartshouse has no intake items listed.
Is there a place you can refer me to online where I can order the good aluminum framed lower intake gaskets or is that a dealer item?
Thanks,
Jon
PostPosted: Sun Dec 23, 2007 7:18 am
........ can be ordered with its own gasket set ........
You have my link confused with the one to ZZperformance, who (according to option #1) charges an extra $20 for the gasket.
Following is from: http://www.automotivepartsnetwork.com/s ... uct=229679
APN.com wrote:
And … it includes everything you’ll need to do the job right!
  • New H.D. Design Manifold
  • High-Temp Gaskets
  • EGR Tube
  • EGR Bushing
  • PCV Valve Adaptor
  • Detailed Step-by-Step Installation Instructions
The gasket comes with the kit, there is no reason to order another.
........ I assume that doesn't include the lowers? ........
I would not expect a lower intake manifold gasket to be included in an upper intake manifold set. That is why I included the following:
........ GM sells a set, with aluminum frames, for about $60 .........
It seals the lower manifold to the heads.
........ where I can order the good aluminum framed lower intake gaskets ........
I get my GM parts from my local GM dealer.
PostPosted: Sun Dec 23, 2007 9:31 am
Thanks for the detailed response.
The help is appreciated.
Jon
PostPosted: Sun Dec 23, 2007 11:01 am
You're welcome. Let us know how it goes.
PostPosted: Sun Dec 23, 2007 3:29 pm
I recommend this one also, I purchased this intake for my mom's 98 Intrigue, 3800 Series II engine. It's a very nice kit, most complete one out there.
PostPosted: Tue Jan 15, 2008 7:33 pm
The design flaw in the upper intake manifolds on the 3800 engines is due to heat from the EGR passage fatiguing the plastic between the EGR passage and coolant passage, allowing the pressure from the cooling system to blow thru the weak area and purge the antifreeze from the cooling system into the engine, often causing a hydrolock condition on the rear bank........
PostPosted: Sat Jul 19, 2008 1:56 pm
If anybody needs a new upper intake manifold for Series 2, I have the aftermarket unit, with gasket, new in box, as well as Genuine GM lower intake gaskets. I'll sell them for well below what I paid. PM me if you need them.
