........ is there a way to determine that I am burning coolant instead of leaking it somewhere? ........
I don't think coolant would burn. Like water, wouldn't it go out the exhaust, in the form of steam? Seems to me, any affected plugs would be “steam cleaned” during the process.
Certainly, the plugs would appear that way, if that were the case. But my question came from this quote:
88Coupe wrote:
........ While small amounts of coolant may not register, my plugs should have shown signs of this when I pulled them ........
Not necessarily. Depends on the size of the leak.
I intrepreted this as the effect on the plugs is dependent on the size of the leak, and that if the leak was small, my plugs may not have indicated signs of coolant contamination, since I had mentioned that my plugs looked normal.
Also, going with the effect on exhaust, the only time I have steam coming out of the tailpipe is when it is cold out, and only until the exhaust warms up and burns off accumilated moisture from the weather conditions.
The word "burn" was the wrong word to use- thanks for the correction.
........ it sits higher in the oil than the side that faces you ........
That would be the area that “could” catch the falling coolant. But only if that area of the stick was not submerged in oil.
And in this case, it is in the middle range of the dipsitck, on the edge, so that part of the stick is submerged.
........ Is that right, or even relatively close? ........
In this case, whether you are right, or wrong, is not the point. Asking oneself these kind of questions, as part of the troubleshooting process, is what separates the men from the boys.
I agree. I meant more along the lines of is my line of thinking correct, or does it make sense- It makes sense to me, and I believe it to be true, but that doesn't make it true. I was begging the question more for reassurance that my explaination to myself was at least logical, not that I was insistent on getting the "answer" correct.
........ Do you believe it would be wise to find the leak before I flush the system ........
I would flush it, and use straight water, until all problems were resolved. Likely, not a practical choice for you, at this time of year.
Yeah, I'll have to flush it and refill it probably at least 50/50, if not 60/40, depending on how the winter goes. Running straight water would be nice, especially if it proves to be internal-
Right now my plan is to wait until I can get my hands on my pressure tester, as that will be what I need to point me in the right direction. Without some hard data and actual diagnosis, we can drive each other mad with possibilities. I was just getting a little too wound up about it; it's a small leak, and there is no hard evidence that it is internal, so it shouldn't be that big of a deal for the little amount of driving I have left to do before I get back home-
Regards,
