It is currently Tue Nov 24, 2026 6:13 am
91parkave
 Posted: Sat Feb 02, 2008 12:58 pm |
88delta88 wrote: 91parkave wrote: ....spray some wd-40 or heavy duty lube of your choice heavily.... WD-40 is not a heavy duty lube.
Nobody ever said it was
Edited:
 Posted: Sat Feb 02, 2008 2:19 pm |
91parkave wrote: 88delta88 wrote: 91parkave wrote: ....spray some wd-40 or heavy duty lube of your choice heavily.... WD-40 is not a heavy duty lube. Nobody ever said they were.
Did you ask them if they were?
 Posted: Sat Feb 02, 2008 2:23 pm |
Here? Where?
 Posted: Sat Feb 02, 2008 11:29 pm |
myfathersoldsmobile wrote: ........ I only did one side, the side that was obviously bad ........ Normally, one would change both sides. 91buickman wrote: ........ i replaced my end links with the polyurethane units ........
Waste of time and money, unless it will be used for slaloms, circle track, or road racing.
 Posted: Sat Feb 02, 2008 11:57 pm |
88delta88 wrote: buickman wrote: ....spray some wd-40 or heavy duty lube of your choice heavily.... Good catch. I missed a real opportunity. 88delta88 wrote: WD-40 is not a heavy duty lube.
Far from it. As a lubricant, it is so light that it is actually a solvent. I wonder how it could make a rattle go away. I also wonder how one might choose between a "heavy duty lube" (chassis grease) and a solvent, for 91buickmans exercise.
 Posted: Sun Feb 03, 2008 1:06 pm |
88 Coupe wrote: ...Far from it. As a lubricant, it is so light that it is actually a solvent. I wonder how it could make a rattle go away. I also wonder how one might choose between a "heavy duty lube" (chassis grease) and a solvent, for 91buickmans exercise.
I remember a WD-40 shootout a while back... Learned a few things!
strokercutlass
 Posted: Wed Feb 06, 2008 2:19 pm |
| TOC Mechanic |
Quote: some wd-40 or heavy duty lube of your choice heavily. where the nut is (surronding rubber) let it soak for a couple of hours and see if the sound is still present.
Norm, you forgot to mention that depending on the product used, it may cause MORE harm than good to spray the product on the rubber bushings......reason being that the lubricant used may actually soften the rubber and cause it to break down and degrade, actually causing more damage to the bushing than helping it, although if it were a silicone based lubricant it may cause the rubber to swell a bit and mask the actual problem.........
Another thing to check regarding the bushings.........I can't remember at this aprticular time which style of front end bushings this car uses, but I've had several newer Grand Prixs in with problems with the forward position lower control arm bushings separating the steel insert from the rubber outer.
Don't worry, Norm.........I've got your back
 Posted: Wed Feb 06, 2008 7:15 pm |
Good to hear from you, again.
strokercutlass wrote: Norm, you forgot to mention that ........ I didn't forget. As we have seen from his erratic posts, he cannot handle that much factual information, at one time, without getting confused. strokercutlass wrote: ........ Don't worry, Norm.........I've got your back ........
I never had any doubts, Old Friend.
91parkave
 Posted: Wed Feb 06, 2008 8:01 pm |
strokercutlass wrote: Quote: some wd-40 or heavy duty lube of your choice heavily. where the nut is (surronding rubber) let it soak for a couple of hours and see if the sound is still present. Norm, you forgot to mention that depending on the product used, it may cause MORE harm than good to spray the product on the rubber bushings......reason being that the lubricant used may actually soften the rubber and cause it to break down and degrade, actually causing more damage to the bushing than helping it, although if it were a silicone based lubricant it may cause the rubber to swell a bit and mask the actual problem......... Another thing to check regarding the bushings.........I can't remember at this aprticular time which style of front end bushings this car uses, but I've had several newer Grand Prixs in with problems with the forward position lower control arm bushings separating the steel insert from the rubber outer. Don't worry, Norm.........I've got your back
Not the issue with GP's they have completley diffrent control arms, and mounts, not to argue with what you are saying but IME ive never seen wd-40 soften a bushing to the extent of what you are saying, maybe a constant basis, if i t was bombarded with wd-40, but not 1 application. as for the actual problem it could be a million and one things hope the op nails it on the first try. or else its a PITA
 Posted: Wed Feb 06, 2008 9:08 pm |
91buickman wrote: ........ they have completley diffrent control arms, and mounts ........ Assuming, your statement is true, what does it have to do with anything? Here it is again: 88 Coupe wrote: 88delta88 wrote: WD-40 is not a heavy duty lube. Far from it. As a lubricant, it is so light that it is actually a solvent. I wonder how it could make a rattle go away. I also wonder how one might choose between a "heavy duty lube" (chassis grease) and a solvent, for 91buickmans exercise ........ Try to keep up with the rest of us. 91buickman wrote: ........ but IME ive never seen ........
I have seen a couple. Judging by his post (and his resume) I believe Stroker has seen many more than I have.
We have seen your BS posts. What about your resume?
Manager of an Autozone outlet? Tech at Mahdavi Motorsports? Presently attending school in Florida?
What you say you have, or have not, seen has nothing to do with anything.
