It is currently Mon Nov 23, 2026 5:28 am
 Page 2 of 2 [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jul 27, 2008 11:46 am
Anyone know why the pins connections on the vehicle side of the connections wouldnt line up with the pins on the GM specific, BLUE, cord? I can read the codes on my F350 and Jeep Cherokee be can get it to work on my olds........
HELP???
Thad
PostPosted: Sun Jul 27, 2008 12:43 pm
Because it's the wrong cable? The connector on the blue cable has 16 pins. How many receptacles are there, in the female connector?
If there are only 12, use the OBD-I GM connector.
FYI: Your duplicate post could have been deleted anytime before I posted this.
PostPosted: Sun Jul 27, 2008 3:09 pm
I am not a total idiot. Its the right connector!!! It's a trapezoid shape. The connector fits it. It has 16 pins and so does the vehicle.
The pin #'s on the vehicle side dont match up to the #'s on the connector. Its like someone moved the wires connections on the vehicle side. I know that sounds crazy.
For example the #12 pin on the cable has nothing to make contact with. I would think if a pin is there on the cable the vehicle side should have something to make contact with.......or am I just crazy.....
If this doesnt make sense I may take a picture, that may help anyhow....
Thad
PostPosted: Sun Jul 27, 2008 9:38 pm
Thad
The question of it being the right cable is not because of the shape of the cable connector, but because of how the connector is wired. There are differences in which pin transmits what info, so you may have the wrong cable.
PostPosted: Mon Jul 28, 2008 1:32 pm
Is there more than one Blue GM specific cable. Since they only specify one Blue GM cable in the manual I would find that totally rediculous.....
but crazier things have happened.....
I guess I was hoping one of the guys that has this tester would reply back....that would be more helpful/practical......
Well after talking to the guys @ Autoxray it seems there is someting aloft. We tried everything they could think of. The pins are in the correct places but not all of them are used by the scanner, so everything was fine there. I tested the vehicle to ensure the signal was being sent which it was but nothing. The scanner worked on two ther of my vehicles but not this one.......just not sure what else to try.....
Thanks
PostPosted: Fri Aug 01, 2008 8:19 pm
No, the pin won't necessarily have anything to go to....as you said, the cable is setup to hook up to a variety of vehicles with an OBD2 plug...not all cars carry the same pin configuration, depending on make and model, options, ABS, airbag, and such.
Have you went back to basics and checked the main things? The scanner must recieve power from the diagnostics plug to be able to operate.....you should have 12 volts all the time on pin 16 of the diagnostics connector....check the 9C fuse in the fuse box...it's a 10 amp.
If that's good I would seriously suggest taking it to a shop that has the PROPER scanner to get into it, and the wiring diagrams to test and see WHY it won't communicate.......I see this constantly with people who go to Autozone to have the codes read, only to find that their "high quality" code reader spit out the wrong code or couldn't read it and cost them alot of $$$ in unnecessary repairs in the long run.
Comparing a $200 code reader against a $3000-7000 diagnostics scanner is kinda like having two guys roofing a house....one on one side with a hammer and nails, the other on the other side with a air nailer....they'll both get the job done, but one will be much faster, more efficient, and probably do a better job....
Money would have better been spent on the AX6000 scanner which shows data stream, graphing, code reading and clearing, AND comes with all the cables with it..
FEATURES
Displays on screen DTCs (Diagnostic Trouble Codes) and code definitions for:
OBD-I codes
OBD-II generic codes
OBD-II manufacturer specific codes
OBD-II Enhanced codes
Supports multiple trouble code requests: generic codes, pending codes and enhanced codes which are stored in the PCM
Displays Enhanced vehicle data for GM, Ford, Chrysler and Toyota
OBD-I Cables
Includes OBD-I Cables for GM, Ford and Chrysler vehicles
Includes EZ-PC AX500
FREE Internet Updates
Graph Drivability Capture Data
Archive Scan & Capture Information
Print Reports and Export Capture Data in Spreadsheet Format
View LIVE sensor data & engine controlled values from vehicle’s on-board computer
Resets Check Engine Light
View Freeze Frame Data
Reads and Displays supported emissions readiness monitor status
Displays supported Vehicle ID Information (VIN#)
O2 sensor readings
Customizable data view
Hard carrying case included
VEHICLE COVERAGE
GM ’82 - Current Year [12 & 16 pin ALDL and OBD-II]
Ford ’83 - Current Year [EEC IV and OBD-II]
Chrysler ’83 - Current Year [SCI and OBD-II]
Jeep ’91 - Current Year [SCI and OBD-II]
Toyota ’96 - Current Year [OBD-II]
Honda ’96 - Current Year [OBD-II]
NISSAN ’96 - Current Year [OBD-II]
All other Asian and European ’96 - Current Year [OBD-II]
Enhanced vehicle data for GM, Ford, Chrysler and Toyota ‘96 - Current Year [OBD-II]
EXTENDED COVERAGE
GM, Ford, Toyota & Chrysler OBD-II Enhanced Data (Chrysler requires special cable - sold separately)
CONTENTS
AX6000 Scanner
GM OBD-I Cable
Ford OBD-I Cable
Chrysler OBD-I Cable
OBD-II Cable (Yellow)
GM OBD-II MFG Specific Cable (Blue)
EZ-PC AX500
Hard Carrying Case
Users Manual
Reg. Card
I don't mean to be critical by ANY means, but you've spent how much money now and are in the same spot you were initially.....just kind of seems like wasted time and $$$...
PostPosted: Mon Aug 04, 2008 12:44 pm
strokercutlass,
You are a day late and a dollar short. That would have been good info about four weeks ago......lol
I dont consider it a waste of $$$ since I have already made good use of my $130 purchase ($90 on the scanner and $40 for the GM cord) on other vehicles (two of mine and my buddies pickup). Locally it costs $70 a shot to have the codes scanned. Even at that rate I am ahead........Although, it would be nice to have a nicer scanner.....
Now in terms of my OLDS I still have issues. I have checked everything on the plug itself ie the proper voltage and resistance. I agree that I may have to take to a professional. If I was back home I would take it to my mechanic but here in Alabama I am having issues finding a good shop....frustrating.....
You dont happen to know of a good shop to take it to in southern AL, do you? lol
PostPosted: Sun Jan 25, 2009 11:39 am
Still have this issue. I have learned to live with it but I just want to fix it so it is right.
The issue is that the "Vehicle is not communicting" with any scanners. Mine, the dealers or the auto shop on Ft. Rucker.
I am trying to find a PCM troubleshooting guide. I dont want to just replace the PCM when it could be something simple like a bad ground or something.
Does anyone know how to go about doing this or have a reference? Any info would be great.
Thanks
Thad
PostPosted: Sun Jan 25, 2009 4:53 pm
Well, I put a new EGR valve in a that solved my problem. Now I just need to be able to read the codes......
Thad
