It is currently Mon Nov 16, 2026 2:06 am
 Page 2 of 2 [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Sun Sep 05, 2004 12:41 am
Now, to update the subject: Since the AMC manifold is on its way back, you might consider taking advantage of the situation to change from the Torker to a performer RPM intake as it is the one Edelbrock designed to work in concert with the RPM cam and RPM heads in the RPM package.
A friend just sent this to me. This from April of '92. It's my first 11 sec. pass in my Grey Coupe.
Hello Norm,
I can't get your link to open.
The engine is already built and has about 100 miles on it. I am pulling the intake to correct an oil leak. At that time I was going to step up to a Torker from the Performer that is on the engine now.
It does not have the Performer RPM camshaft installed.
70 442 Holiday Coupe (curb weight 3817 lbs)
Fresh Engine
470 ci
Performer RPM heads and Performer intake
9.75:1 CR
Holley 830 HP (Pro Systems assembled Pro Series 4150 950 CFM built for the street and ready to install)
Pertronix Flame Thrower HEI
Camshaft -
230°/240° @ .050
.522" Intake Lift
.542" Exhaust Lift
110° Lobe Separation
1400-6000 RPM Range
Thorley headers 1 3/4" tubes 3" collector
Torque Tech 3" X-pipe system w/ 22" large case Aero Chamber mufflers
TCI Turbo 400
10" 2800 RPM stall converter
Moser complete axle assembly 4.11:1 pro gears w/ Eaton 33 spline posi
28" tall P275/60R15 Drag Radials
Thanks,
John
This was my father's Oldsmobile!
PostPosted: Sun Sep 05, 2004 1:06 am
Images: 3
Turbocharged400sbc wrote:
doesnt matter anyway cause if the heads do or dont have the heat riser/crossover it wont matter as your new intake wont have it so regardless it doesnt matter.
The Olds Torker intake does have provisions for the heat crossover. But it won't need to be blocked since the RPM heads don't have a crossover to begin with.
Maybe thats what you meant?
And just for clarification for Blonzz, here is a picture of the Olds RPM head with a large red elipse where the heat crossover would normally be on an Olds head:
468/T-56/3.73
PostPosted: Sun Sep 05, 2004 1:28 am
Hi Blonzz, hello All
I opened it with Firefox before I posted it, and again, just now, with IE5.5. Try right clicking the link, and choose "save link as".
Fresh Engine
470 ci
9.75:1 CR
Camshaft -
230°/240° @ .050
.522" Intake Lift
.542" Exhaust Lift
1400-6000 RPM Range
TCI Turbo 400
I forgot you're using the man sized carb. You've got enough cam and carb to make the Torker easily the better choice.
Also if you told the carb guy you were using it, he tuned it for a Torker.
PostPosted: Sun Sep 05, 2004 1:48 am
Hi BigBlockOlds, Blonzz, hello all
Thanks, BigBlock: It did not occur to me that Blonzz might not know that information, although I should have understood it from his initial post.
PostPosted: Sun Sep 05, 2004 11:37 am
Thanks everone!
John
