It is currently Mon Nov 16, 2026 4:38 am
 Posted: Tue Mar 01, 2005 3:16 pm |
Hi 85cieraholiday, all
Quote: ............ Hold the gas pedel to the floor and turn the key and the car will start right up ............
Good advice for a carbureted engine but I'm pretty sure a '91 would be injected, and it would make it harder to start.
 Posted: Tue Mar 01, 2005 4:44 pm |
Quote: Mine is fuel injected.
TB or Port?
I understood flooring a TB will keep it from starting and thought it would carry over to the later systems.
Manuals for the first TBIs cautioned the operator not to touch the pedal during startup.
Not the first time I've been wrong
Oldsmowbill
 Posted: Tue Mar 01, 2005 11:45 pm |
Joined: Fri Dec 10, 2004 6:08 am Posts: 22 Location: Campbellsville, Ky
Quote: My car does the same thing, you probly have a bad temp. sensor. When you turn the key, the car floods itself and becomes hard to start. When It floods the plugs get covered in gas causing loss of spark. Hold the gas pedel to the floor and turn the key and the car will start right up, if the plugs are wet clean them or if needed replace them.
Like the old days, I did try to hold the gas pedal to the floor on this fuel injected system with no results.
Do note that I observed zero spark when I removed the spark plug and connected it back to the wire and held it to chassis ground and had an assist to crank on the engine.
I believe it's a spark/ignition thingy and I'm currently working on it.
I did test all three coils on the 3.3L and they all showed infinite high resistance in which the Haynes manual said it should if they're good.
Anyone know of any way to test the ignition control module via ohmeter?
I have a control module on the way that I'm going to slap on there. I got lucky and found a brand new AC Delco Ignition Control Module for this engine for $30 off off Ebay. (They are $136.00 at the parts house!)
Turbocharged400sbc
 Posted: Thu Mar 03, 2005 1:32 am |
you will need a DSO or a graphing digital multi meter to see the crank sensor signals and to make sure the signal is the correct form.
BTW when you floor the pedal on any FI vehicle the ECM/PCM goes into clear flood mode and does not deliver injector pulse, but continues to fire the plugs, when the 'puter see's the engine increase beyond cranking speed (600-800rpm) it then enables injector pulse.
Oldsmobill have you checked for injector pulsing with a noid light?
you have no spark. the ignition module gets the crank sensor signal and then sends it to the ECM/PCM for it to use it for injector batch firing. so your down to the crank sensor and ignition module if you dont have chewed up wires somewhere (check the wires comming outa the crank sensor as sometimes the loom gets loose and will rub the crank pully/belt. also realize that the crank sensor should have a 5 volt feed-make sure you have 5v at one of the crank sensor wires (orange if i rem correctly) this is the same 5v source that the TPS uses so check for it there too.
good luck, and happy hunting,
James
 Posted: Thu Mar 03, 2005 2:23 pm |
Hi Turbocharged400sbc, all,
Quote: ............ when you floor the pedal on any FI vehicle the ECM/PCM goes into clear flood mode and does not deliver injector pulse .............
I stand corrected ............. I think.
Turbocharged400sbc
 Posted: Thu Mar 03, 2005 2:32 pm |
88 Coupe wrote: Hi Turbocharged400sbc, all, Quote: ............ when you floor the pedal on any FI vehicle the ECM/PCM goes into clear flood mode and does not deliver injector pulse ............. I stand corrected ............. I think.  Regards, Norm
LOL sorry Norm, i forgot about the Rodchester mechanical fuel injection systems those dont do the clear flood at WOT cranking. LOL
 Posted: Fri Mar 04, 2005 6:12 pm |
TPS = throttle position sensor. Used to tell the computer how far you've pushed on the gas pedal.
NOID light = I think he's talking about a neon timing light. Its like a strobe light that you connect to the plug wire, and it flashes every time the engine fires that spark plug. Used to time older vehicles with distributors. Many other uses aswell.
Crank sensor just has to be lined up so that the harmonic balancer doesnt rip it off when it rotates. You'll see what has to be done once you get down under the car.
strokercutlass
 Posted: Mon Mar 07, 2005 11:22 pm |
| TOC Mechanic |
A noid light is used to check injector pulse...it plugs into the injector harness at the injector itself to show if the computer is telling the injector to fire or not.
If the crank sensor on the 3.3 is similar to the 3.8 (hardly ever see a 3.3 roll thru the shop anymore so I honestly can't remember....damn I'm feeling old :? ) then you are supposed to have a specific amount of gap between the sensor and the reluctor ring..that is what they're explaining when they discuss using a special tool for setting the crank sensor. Also, if the 3.3 harmonic balancer is similar to a 3.8 one, on some engines a special harmonic balancer puller will be required. I've seen some 3.8's which have a slip-on balancer, others which have a pressed on one which requires a special balancer puller...doesn't seem to be any rhyme or reason to which has which.
I've also personally seen 3.8 cars with a stored code 43 ESC code which ran for a long time, but did have slight problems with tip in throttle response....strange but true.
As someone else had said, you may also want to check the wiring between the crank sensor and ignition module for chafing, rubbing, or the occasional crazed hungry mouse
