It is currently Tue Nov 24, 2026 2:09 pm
85cieraholiday
 Posted: Mon Sep 17, 2007 8:51 am |
I would then go with a fuel delivery test, which seems most likely, as once it starts, it runs. Take off the fuel inlet and put it into a container, and have a friend cycle the key. It should pump a decent amount of fuel. A FSM would tell you what an acceptable volume is. If it is not pumping fuel well, or seems weak (that would require mechanical intuition or "feel", I think you will be able to tell if it is weak) then that would tell you there is a problem with either the fuel pump, fuel filter, or fuel lines leading up to the fuel rail.
If you have a good volume of fuel being delivered, and none to the engine, we then know the problem is further down the line, like with a pressure regulator, or a fuel rail, injector, etc, etc.
This is where I would start, if it were mine. Hope this helps you-
Where is the "fuel inlet"? This is all new to me so please bear with me.
_________________ .
 Posted: Mon Sep 17, 2007 4:47 pm |
85cieraholiday wrote: ........ Where is the "fuel inlet"? ........
There is a test port (should be on a fuel rail) that has a "schrader" (as used in the valve stems on your wheels) valve.
Pressure should be 41-47#, unless the FSM or Brando's Alldata says different.
You should be able to rent, or borrow, the proper gauge from your local auto parts supplier.
 Posted: Mon Sep 17, 2007 11:11 pm |
91parkave wrote: go to autozone if available like norm said, you can rent one or buy one, and yes that is the proper tool listed best of luck on this one.
-marshall
No, that is not the proper tool listed...that's for carbureted vehicles...notice the low PSI ratings (0-15 PSI)?
This one should do the trick. If you have a Murray's or Autozone you can most likely rent the fuel pressure gauge for the price of the tool and when you bring it back you get your money back. Of course, a fuel pressure gauge is a handy thing to have...so it's up to you.
VIN CODE C 3.8 should have fuel pressure of 40-47 PSI with ignition on (not running), and 31-43 at idle. It also says that if you briefly block the return line, the fuel pump pressure should read 75 PSI minimum.
This is all measured at the fuel rail, it's called a "schrader valve." You just remove the protective cover and screw the pressure gauge on (works like a tire air valve). It is advisable to release any fuel pressure first. Remove the fuel pump fuse and crank it for a while....then for testing replace the fuse.
85cieraholiday
 Posted: Tue Sep 18, 2007 8:40 am |
88 Coupe wrote: 85cieraholiday wrote: ........ Where is the "fuel inlet"? ........ There is a test port (should be on a fuel rail) that has a "schrader" (as used in the valve stems on your wheels) valve. Pressure should be 41-47#, unless the FSM or Brando's Alldata says different. You should be able to rent, or borrow, the proper gauge from your local auto parts supplier. Norm
I found the test port, once I find a gauge Ill follow the directions provided and report back.
_________________ .
 Posted: Tue Sep 18, 2007 2:36 pm |
Well...I'm not sure...
ALLDATA says you need to disconnect the fuel tank harness....which I'm not sure exactly where it is...looks like it might be under the rear seat....or it could be under the car...pictures not quite clear...
But there are two fuses in the fuel pump diagram....number 16 in the fuse panel - 20 amp and a 20 amp fuse in the relay center - number 6. Try one or both of those.
As far as blocking the line you would probably use a rubber plug and have someone hold it in place while you crank it or vice versa...
The fuel pressures look perfectly fine though, I think it's safe to say the fuel pump itself is ok and not the cause of the no start situation.
Do you hear the fuel pump running when it won't start (ignition set to on, not cranking)? Perhaps you have a bad fuel pump relay...
Check this out:
http://www.misterfixit.com/fuelrlay.htm
Here's some diagrams:
The fuel pump relay is located behind the right hand side of the instrument panel in the relay center.
85cieraholiday
 Posted: Sat Sep 22, 2007 11:31 am |
Update:
I am still trying to get the problem resolved but the darn thing keeps starting right up. Maybe one of the pot holes on my way to school shook the car back together  .
_________________ .
 Posted: Sat Sep 22, 2007 6:37 pm |
When the temps drop, is the humidity high?
If so, plug wires could be the cause.
Turbocharged400sbc wrote: ........ take a spray bottle with some soapy water in it and spray down the wires at the coilpack to the plugs and with the lights out and it dark while the engine is running and you will see a nice little lightning show ........
Cheap and easy test.
85cieraholiday
 Posted: Sat Sep 22, 2007 9:36 pm |
88 Coupe wrote: When the temps drop, is the humidity high?
Yes, I will test this during the week and report back with my findings.
_________________ .
 Posted: Thu Sep 27, 2007 7:30 pm |
LOL, yea...that AAA card comes in handy sometimes...
