It is currently Wed Nov 25, 2026 7:13 am
 Page 3 of 3 [ 31 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Bad TPS?
PostPosted: Mon Oct 01, 2007 5:46 pm
Alright guys- got it done this afternoon. Here is the full "write-up"
I replaced fuel injectors on number 1 and number 2 cylinders. Number 2 was a dead short, and number 1 injector was weak at about 10 ohms resistance. The others were all fine at 12 ohms or above. Highest was 12.5 ohms, lowest was 12 ohms even. After replacing the injectors, I retested using the node light, and I had good pulse. I re-checked fuel pressure, and it was, again, right at 45psi. Tested spark, had good, crisp spark. Tested the ignition coils, all tested great. Primaries all tested at .85-.90 ohms, secondaries all tested at 8700-9500 ohms. I tested the TPS sensor as part of my original diagnosis, and it was within spec. Idle was .45 VDC, and WOT was 4.8 VDC. I ensured I had 5 VDC to the MAP sensor, and I cleaned the EGR valve, and the IAC motor.
Then came the fun part, which was fixing someone else's screw-up. When I first got my car, I lived with my parents, who were never keen on letting me work on my own vehicles. They let it go with my Oldsmobile stuff, but they wanted someone to be accountable for the work on this car. I wish I could find the guy we had work on it, so I could give him a piece of my mind.
I don't know how familiar you all are with the early 3.1 engine, but they are known for vacuum leaks from the hard plastic lines that go from the lower intake manifold to the throttle body. My car broke one of these lines, so I took it to the mechanic we had working on my car.
Previous to this repair, he exhibited a high level of professionalism, and good quality work, so I had no problems letting him fix it. To do the repair, one must remove the upper intake manifold, and replace, or patch the lines, then reassemble.
The bolts that hold the upper intake on the 3.1 are unique. They have a rubber grommet on the head, and they have a collar that bottoms out on the lower intake manifold, which lets the upper intake manifold just pinch the rubber coated intake plenum gaskets, to ensure a good seal.
The mechanic must not have known this, because he totally jerry-rigged my car. He must have put those bolts in with an impact wrench (torque spec is 88in/lbs, which is very light) because they were all bent, and two were broken off. The collars on the bolts had been driven into the lower intake manifold, leaving nice rings gouged into the intake mating surface. To fix his mistake, he put regular washers on the bolts, and tightened them way down to pinch the intake gaskets. It was, and pardon my french, a complete fuck-up. When I got the car back, I asked him what he did to my car, and he said "I guarantee it will hold." I told him that wasn't the point... But I am digressing. Needless to say, he is no longer around, and that's too bad, as I would love to tell him where he can put all these bent bolts I have.
To make it more interesting, according to the GM dealer in town, those rubber grommets are NLA, so I had to find some at the local junk yard that weren't dried and cracked. I was lucky to find some that were in real good shape. I haven't looked on-line, but I have a feeling that those grommets are available somewhere, but its a bygone now.
After I chased all the threads, and cleaned up the ridges the collars had left, I installed all new gaskets (Standard Motor Products makes a plenum kit that comes with all the gaskets you need for this job, part number PG26. They are based in NY state, but who knows where these are made...) and installed the bolts and grommets that I sourced.
I then torqued everything do to specified torque, reconnected everything, and tried to start it up. It started right away, and hasn't run this good in a long time. Idle quality is significantly improved, and it runs smoother overall. I'd say this "performance mod" has given me at least 20 FWHP :lol: Just kidding, of course.
In conclusion, this should have been easier than it was, but when you have to fix others mistakes, it makes it harder to do right. Hopefully now my car will run for awhile!
Regards,
