It is currently Thu Nov 12, 2026 6:58 pm
 Page 4 of 4 [ 54 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Wed Mar 08, 2006 5:36 pm
A pulse detector will tell you if the electrical portion of the injection system is working properly. That may not be a bad idea. But I think the problem would be with the physical injector itself not opening or spraying an uneven mist.
If that is the case, I am not sure how you would tell which injector is clogged without removing and benchtesting each one.
PostPosted: Wed Mar 08, 2006 7:46 pm
Hi All,
92olds88royalle wrote:
........ been working with some people on bonneville club ........
"bill buttermore" is doing a fine job, click here, do exactly as he says.
PostPosted: Wed Mar 08, 2006 11:01 pm
thanks norm and everyone else ill let you guys know the end result
PostPosted: Thu Mar 23, 2006 6:04 pm
i was recomended to buy a breather for the oil filler cap to see the change in idle quality and see if the computer recognises it. any idea what size i should get?
PostPosted: Thu Mar 23, 2006 6:17 pm
A new oil filler cap? or a breather? I would think at your parts store, there will be a book of universal oil fill caps... That would be my best guess.
PostPosted: Thu Mar 23, 2006 6:21 pm
a breather
PostPosted: Thu Mar 23, 2006 9:41 pm
88delta88 wrote:
........ I would think at your parts store, there will be a book of universal oil fill caps ........
That same book will also contain the part number for the OEM replacement cap.
........ any idea what size i should get?
If you get the correct cap, it will be the right size.
a breather
The breather for your application will be in the same book.
At your knowledge level, cross posting does more harm than good. More so, when the posts contain different information.
PostPosted: Thu Mar 23, 2006 11:54 pm
i just needed to know what size the oil filler cap hole was so i could get the breather, nothing more
PostPosted: Sat Mar 25, 2006 12:37 pm
Ok had my friends brother take the car yesterday. he hooked it up on vaccum guages and everything and it turned out to be the o2 sensor i replaced 2 months before the problem started with a cheap o2 sensor. My guess is when i was cranking down the back spark plugs i hit the o2 sensor and messed it up somehow. Well anyways thanks for all your help norm and everyone.
