It is currently Fri Nov 06, 2026 12:23 pm
 Page 4 of 5 [ 68 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Carburetor problem??
PostPosted: Wed Jan 24, 2007 9:40 pm
GraveReaper0 wrote:
........ could that plug have anything to do with emissions?
Maybe, maybe not. Did you find where it goes, yet?
........ Replace the hose, put it back, then show us a pic of the other end.
Yes.
GraveReaper0 wrote:
........ It goes in the intake into a metal hole, so its not air tight. Is it supposed to be?
Maybe, maybe not. Put it back, and show us a pic of it, in place.
Also we need to see more of the Choke housing and its black cover. Phillips screw under your arrow is one of three holding it on. Check for two electrical connectors at the bottom (under the hose) of the black disk.
PostPosted: Thu Jan 25, 2007 6:17 pm
Alright. Took out the rods for more pics, took off the black cover on the side. Here's the other side:
And the inside. for some reason my camera didn't want to zoom in, even in close up mode.
Here/s the metal hose I was talking about, the right one.
Comes out easy, and i can push it back in easy.
I don't know what you mean by disc with two wires, but I did find this.
And I can't seem to find the pot.
Here are the rods.
#1
#2
Also I noticed today when my engine is running, the flaps are closed off completely because this:
is all the way in and won't budge, but once I tun it off, I can open it manually. the engine was a little cold today because of the short ride home so the choke wasn't even open fully yet, don't know if that makes a difference.
PostPosted: Thu Jan 25, 2007 7:33 pm
........ Once you find this, follow Norm's instructions.
Actually that should have been: Follow Norms instructions, and look for it, if ........
PostPosted: Thu Jan 25, 2007 9:57 pm
GraveReaper0 wrote:
........ took off the black cover on the side. Here's the other side ........
I'm guessing there are no wire connectors on the side we cannot see?
GraveReaper0 wrote:
........ Here's the metal hose I was talking about, the right one .........
Metal hose = tube
If the tube on the left, goes to the rear of the choke housing you just took apart, the right one is it's (filtered) fresh air supply. Air goes into the chamber below the plate (choke stove) to be heated on it's way (via the left tube) to the choke thermostat,
where the heat causes the (bi-metal) spring to unwind, opening the choke.
It's not supposed to be loose. but it doesn't matter, as long as it doesn't fall out on it's own.
As an aside: I did not know they still used stoves in '88.
GraveReaper0 wrote:
........ I don't know what you mean by disc with two wires, but I did find this ........
Those are not wires, they are hoses. I do not see enough of the area to ID the part.
GraveReaper0 wrote:
........ And I can't seem to find the pot ........
Here the instructions, again.
........ With the engine speed at idle, note the difference in position of anything in the marked areas?
If no difference, see if there is a vacuum hose connected to the pot at the bottom right. If there is, check for vacuum at the hose ........
"If no difference" were the operative words.
GraveReaper0 wrote:
........ Here are the rods ........
I don't see anything to be concerned about, you can put them back.
GraveReaper0 wrote:
........ Also I noticed today when my engine is running, the flaps are closed off completely ........
Flaps = secondary air valve. Is it closed when the engine is off?
Because the pot you did not need to look for, is working like it should, it will not let it open unless there is a vacuum drop. Going to WOT, for instance.
GraveReaper0 wrote:
........ is all the way in and won't budge, but once I turn it off, I can open it manually .........
Proof that it is working properly.
Has the green rod fallen out of its slot, yet?
GraveReaper0 wrote:
........ don't know if that makes a difference.
Not a bit.
Now comes the interesting part.
Since, I did not tell you to remove the thermostat (remember the three screws?), I did not tell you to mark its position. Loosening the screws and turning it, is how the choke is adjusted.
See if your manual tells you how to adjust the choke. If so, do it. If not, Report back.
PostPosted: Fri Jan 26, 2007 12:41 am
Nope
So if its working properly and i'll let it go WOT while Im watching it with the air filter off I should see the secondaries open?
Uh, no, but it is loose since the bolt is gone. But it doesn't seem like it should fall out, a curve in the rod is holding it.
I'll look in the manual before I go to bed and report tomorrow.
Also, when I was removing the three screws from the black cover, they were on pretty tight, so I had to push a little to turn them. Well, When I got to the bottom one, the hole it was in jst bent. How bad is that?
PostPosted: Fri Jan 26, 2007 3:20 am
Should have asked, in my last post.
Is the secondary air valve fully closed when the engine is off?
GraveReaper0 wrote:
........ So if its working properly and It'll let it go WOT while I'm watching it with the air filter off I should see the secondaries open? ........
1) It's a stupid thing to do.
2) No. They do not open unless the engine needs more carb. Not possible under those circumstances.
GraveReaper0 wrote:
........ a curve in the rod is holding it ........
Are we surprised?
GraveReaper0 wrote:
........ the hole it was in jst bent.
Explain.
PostPosted: Fri Jan 26, 2007 5:23 pm
...Now comes the interesting part.
Since, I did not tell you to remove the thermostat (remember the three screws?), I did not tell you to mark its position. Loosening the screws and turning it, is how the choke is adjusted...
He can reference where the choke was, with this earlier picture he took:
It will at least show him where it was to begin with. He can fine-tune it with his manual like you suggested, norm.
PostPosted: Fri Jan 26, 2007 6:33 pm
Are we surprised?
Is there a point to this? You seem to be pretty concerned about that rod for some reason.
I just checked the carb after letting it warm up, and yes they do stay closed even after I turn it off. But like I said I can open it by hand easy.
PostPosted: Fri Jan 26, 2007 6:46 pm
GraveReaper0 wrote:
Are we surprised?
My take is that you were wondering what would hold the rod in after that nut and bolt was removed. Now, you see how it operates, and you have learned something.
But, I'll let Norm speak for himself.
PostPosted: Fri Jan 26, 2007 9:58 pm
88delta88 wrote:
He can reference where the choke was, with this earlier picture ........
Good thinking.
GraveReaper0 wrote:
Is there a point to this? ........
Yes.
There is a point to everything I say, and do. Some get it, some do not.
GraveReaper0 wrote:
........ I just checked the carb after letting it warm up ........
Temp makes no difference.
GraveReaper0 wrote:
........ yes they do stay closed even after I turn it off ........
Since that is what they are supposed to do, it looks like they are adjusted properly. We will find out, as we continue.
GraveReaper0 wrote:
........ But like I said I can open it by hand easy.
Yes, you said that. The question was to address the part you did not say.
With the engine off, and the choke closed, see if the above linkage moves when the throttle is opened fully.
Repeat, while manually holding the choke open.
Did you find where this belongs?
........ Now, you see how it operates, and you have learned something ........
Make that, "and everyone has learned something".
PostPosted: Mon Jan 29, 2007 7:05 pm
Man I was pissed off today morning. I haven't drove the car in 2 days and its been a couple of COLD ones. Tried starting it but its just wouldn't catch. After a few minues the battery drained. Then I try again but instead of cranking the engine, it made a really loud whining sound, something just kept spinning till it completely drained the battery, may be the starter? While it was doing that the tachometer shot all the way to 8,000. After that I got my gf to help me jump my car. after 10 more minutes of trying to crank it it finally started.
Why does it have such a hard time staring when its cold?
PostPosted: Mon Jan 29, 2007 8:36 pm
GraveReaper0 wrote:
Man I was pissed off today morning ........
Did that help you solve your problem? Do you think if I tried being PO, it would make me a better troubleshooter?
GraveReaper0 wrote:
........ Why does it have such a hard time staring when its cold?
I will take a wild guess.
You have not followed my instructions and because of that, there is still a problem with your carb.
PostPosted: Tue Feb 20, 2007 2:04 am
Well the carb is fixed, I think. On cold days it will start if I pump it 3-4 times and try and start it and repeat that process 2-3 times. The problem was that the choke stayed opened even after it cooled down. Sometimes it still backfires, but today was the first time it did it since the fix. I believe its got something to do with my timing. The idle is down to its normal, the mechanic showed me how to do it.
And that litle doo-hikie plug is for a trans with OD, which I don't have anymore.
So now how can I start working on my codes?
PostPosted: Tue Feb 20, 2007 2:52 am
GraveReaper0 wrote:
........ On cold days it will start if I pump it 3-4 times and try and start it and repeat that process 2-3 times ........
Choke is out of adjustment.
GraveReaper0 wrote:
........ Sometimes it still backfires ........
Not surprising.
GraveReaper0 wrote:
........ I believe its got something to do with my timing ........
Right. You got ⅔ of the way through setting up you carb, then quit because you think your timing is off.
GraveReaper0 wrote:
........ The idle is down to its normal ........
Good thing you found out how. Might come in handy in the future.
GraveReaper0 wrote:
........ the mechanic showed me how to do it ........
Did he tell you why it was set that high?
GraveReaper0 wrote:
........ how can I start working on my codes?
Your mechanic can show you how. Right after he finishes setting up your carb for you.
PostPosted: Sat Mar 24, 2007 7:50 pm
Well. Today I took the car over to him again. He adjusted and cleaned my carb, adjusted the timing, and found out my baro sensor was hooked up to a vacuum hose for some reason.
The new sensor was free, thanks to a local yunk yard, and he took 60 buks. No more codes flashing, and she's purring nice.
