It is currently Sun Nov 15, 2026 12:34 am
 Posted: Tue Feb 06, 2007 1:32 am |
Wild suggestion: check that vacuum hose for the regulator over closely. I dunno if the gas could have dried out the rubber boots, and is leaking vacuum.
 Posted: Sat Feb 17, 2007 10:54 am |
I am thinking about the IAC motor on my car. It closes to restrict air flow when the engine is cold. If it were to fail to open, it would definitely cause some problems. I believe mine is vacuum operated, by a module behind the intake manifold. Check the hose for cracks, missing hose etc...
 Posted: Thu Mar 01, 2007 9:51 am |
Thats definately the mass airflow sensor you unplugged. It is different than the maf on my car, and unplugging it should make the check engine light illuminate.
If it doesnt come on, you might have a burnt out check engine light, which would explain a lot. If that is the case, there are likely codes stored in there that would help you out, but you couldnt read them because the light burnt out.
The check engine light should come on for a few seconds at startup, so you can see it is working. Check that out. Might save you a lot of time.
 Posted: Tue Mar 06, 2007 10:55 am |
 no problems, sorry you had to let it go. Sometimes cars are more frustration than they're worth. You let the rims go with it?
 Posted: Sat Jul 14, 2007 2:56 pm |
We may never know, because, he has sold the car. Check a few posts above.
 Posted: Sat Jul 14, 2007 4:15 pm |
Shambler998 wrote: Have you considered the Catalytic Converter? It was already (literately as well as figuratively) eliminated. http://www.oldsconnection.com/forum/vie ... 346䮒zerepdivad wrote: Ok well today i cut out the catalytic converter ........
