It is currently Fri Nov 06, 2026 12:23 pm
 Posted: Sat Mar 24, 2007 10:07 pm |
GraveReaper0 wrote: ........ and he took 60 buks ........
What a coincidence. That is about 60 bucks more than it would have cost, if you had not bailed out of this thread.
In return for your $60.00, you missed the opportunity to learn how to diagnose and repair it yourself, along with the satisfaction that comes from doing it yourself.
The part that bothers me most is, that by bailing out, you took the same learning opportunity away from many present, and future vistors. Learning is, after all, why we are here.
Or, to put into a form, even you can understand: That $60.00 could have bought you a lot of beer.
 Posted: Mon Mar 26, 2007 5:27 pm |
GraveReaper0 wrote: ........ you're help wasn't worth s*** ........ Tell us why you think so. GraveReaper0 wrote: ........ Go hijack someone elses thread ........
Where would you get the idea that I would hijack anyones thread? Can you post an example?
 Posted: Mon Mar 26, 2007 5:33 pm |
GraveReaper0 wrote: Coupe fuck you, you're help wasn't worth shit. Go hijack someone elses thread, I know how much you love that.
I like how its "fuck you" when you don't need help, and "please help me" when you do.
Diagnostic theory is as follows. Most likely, to less likely. Certain systems in a carb have to be working properly in order for the other systems to work properly. You were halfway there. Just because you quit doesn't make it bad advice.
As for thread hijacks, look in the mirror.
 Posted: Tue Mar 27, 2007 9:29 pm |
OldsGuy wrote: ........ you were teaching a class ........ Whenever given the chance, it's what I do, here and elsewhere. OldsGuy wrote: ........ Kudos to your patience ........ Thanks. Emotional outbursts from the 1% notwithstanding, one only needs to keep focused on the reason we are all here. OldsGuy wrote: ........ learned something myself about quadrajets this morning ........
Too bad he bailed out. It was a near perfect teaching aid, and we were just starting the parts that deal with, both, power and driveability.
GraveReaper0
 Posted: Sun Apr 01, 2007 9:34 pm |
88 Coupe wrote: GraveReaper0 wrote: ........ how can I start working on my codes? Your mechanic can show you how. Right after he finishes setting up your carb for you. Norm
 Posted: Mon Apr 02, 2007 1:37 am |
88 Coupe wrote: GraveReaper0 wrote: ........ I've got 4 codes popping up ........ Now we know the comp is hooked up, so we have another piece of the puzzle. GraveReaper0 wrote: ........ Should I do the diagnostic again with the engine running? ........ Not needed yet. We can do it when we are actually looking for codes ........ 88 Coupe wrote:  With the engine off, and the choke closed, see if the above linkage moves when the throttle is opened fully. Repeat, while manually holding the choke open ........ 88 Coupe wrote: GraveReaper0 wrote: Well the carb is fixed, I think ........ the mechanic showed me how to do it.
So now how can I start working on my codes? Your mechanic can show you how. Right after he finishes setting up your carb for you.
What is your point?
