It is currently Wed Nov 18, 2026 7:33 am
Oldsmowbill
 Posted: Fri Dec 10, 2004 6:24 am |
Joined: Fri Dec 10, 2004 6:08 am Posts: 22 Location: Campbellsville, Ky
Engine: 3.8
Miles: 130K
Symptom:
This has only recently been occuring in the last couple of days and started happing all of the sudden.
It seems like when I'm taking off from stop, the whole car vibrates and if I let off the gas a little, it smooths out. If I step on the gas real hard and fast and take it all the way to the floor, there will be a "pop". One time, it died when I did this.
Occurances:
The first time it happened, I noticed this and drove it back home and jumped in my backup car. Later on that night, I got back in the Olds and noticed that it did this only for a few seconds and never did it anymore.
Couple of days later, it did this again but I drove about 20 miles and it smoothed out.
So, does anyone have any recommendations on a good troubleshooting starting point?
Thanks!!
 Posted: Fri Dec 10, 2004 9:38 pm |
speedy266 wrote: MAF sensor? which 3.8L engine do u have? 1991 Ciera's came with 3.8L's?? i thought the last year of 3.8L's in cieras was 1988.
Good call...probably the 3.3L, unless he did a swap...
 Posted: Fri Dec 10, 2004 10:01 pm |
I had the same problem... My car backfired at times, and it was caused by a damaged plug-wire boot and it was arcing straight over to the next spark plug wire, and firing that cylinder at the wrong time.
The boot was damaged at the ignition block, and would just jump to the next wire. I only figured this out becuase I actually saw a blue spark jump by accident, and said AHA!
Just a suggestion
Turbocharged400sbc
 Posted: Fri Dec 10, 2004 11:58 pm |
ah here we go! 88delta88 has it on the money look at your ignition cables (spark plug wires) closely, 130k miles, if it was last tuned up at 70k (plugs/wires/pcv/etc) you may be needin it soon! the bast i can surmize is it might have been humid the days you had the problem (rainy lately? etc) and they atarted arcing once they start arcing the carbon tracks let it ark at the slightest bit of engine loading.
take a spray bottle with some soapy water in it and spray down the wires at the coilpack to the plugs and with the lights out and it dark while the engine is running and you will see a nice little lightning show
(dare ya to stick your tounge on it! LOL-better than coffe in the mornin!)
where the voltage leak is (usually near the coilpack or the plug boots)
then replace your spark plug wires with some quality ones (cheapo's are for when you SELL the car lol) (ACDelco, Belden etc) and get new plugs and put them in also (with correct gap) (helps to put the silicon Dielectric grease inside the ends of the wire boots-makes removing them easier next time-this is sometimes included with the wires)
hope i could help ya some
BTW not much else can cause the problem your experiencing (unless a squirel/rodent chewed through some harness wires LOL)
Oldsmowbill
 Posted: Sat Dec 11, 2004 6:46 am |
Quote: the bast i can surmize is it might have been humid the days you had the problem (rainy lately? etc) and they atarted arcing once they start arcing the carbon tracks let it ark at the slightest bit of engine loading.
Yes. As a matter of fact, it's been raining for the last two weeks and this has been happening during this time.
The worst I've seen it run was the other night when it was really damp and foggy.
Turbocharged400sbc
 Posted: Sat Dec 11, 2004 10:47 pm |
replaced your plugs/wires yet?
 Posted: Wed Jan 12, 2005 7:26 pm |
Taking a while to replace those plugs and wires! :?
