It is currently Wed Nov 18, 2026 7:39 am
PostPosted: Mon Jan 31, 2005 1:01 pm
I have a "tail wagging" or swaying coming from the rear while driving at low speeds.
A noticible vibration comes from the front end while braking. No noise from the drive train otherwise.
Lower ball joints in front appear to have collapsed boots and grease fitting on right is frozen.
Continuous pull to the left. Left brake pads are noticably worn on left, though changed less than 10k miles ago.
Any help would be appreciated.
PostPosted: Mon Jan 31, 2005 2:49 pm
1 tail wagging in the rear at low speeds-more than likely one of your rear tires has slipped a belt and the tire being out of shape is wagging, also check for a bent rim as it is also very similar.
2 vibration from front while braking, do you feel it mostly through the steering wheel or floor? this is very likely to be warped rotors, from it being too thin, to one of your calipers sticking and dragging the pads (this kinda relates to your left pull)
3 front lwr ball joints-boots collapsed? the dust seal is usually a bit of rubber etc and usually has a couple o ridges-the question here is is the lwr ball joint wornout? you will need to jack up the vehicle and get the weight off the lwr control arm/strut and try to move it around (shake wheel vertically while someone looks at the joint)-if the grease fitting is frozen you can replace it (if a screw in type) or if the joints still good wait for it to wear out lol - no point in replacing a grease fitting if the ball joints loose and needs to be replaced lol.
4 pull to the left it seems that you can verify that the left pads are worn more than the right and less than 10K after replacement. essentially your brakes are dragging on that side (wearing faster) as well as pulling your car to the left.
first thing to look for is are the caliper slides (pins that the ccaliper moves on (floating) free, does the caliper move easily on the pins,-more than likely 3/8 inch hex or later Torx T 50 to remove these- rust can build up under the rubber boot (sleve) and squese tight on the pins and cause pad dragging.
second is how rusty are the pad contack points are the pads slip right into place or, are rusted there?
is the caliper's piston possibly stuck in it bore (if you try to push the piston back to put new pads in does it move properly) or possibly a collapsed brake hose (the rubber one-line to the caliper-) with this see how the difference is moving the rotor before and after cracking the bleed screw loose or the bolt that holds the brake hose banjo fitting (if ya get a spurt of fluid- some hydraulic system pressure was still present-9 outa 10 are usually the hose),
you could just replace everything but if ya dont mind brake fluid on your hands you can check all of this and maybe save ya some $
good hunting schlim
