It is currently Wed Nov 18, 2026 7:55 am
PostPosted: Sat Feb 05, 2005 7:56 pm
I have a cutlass take has a small stream of coolant that seems to be running down the side of my intake. It's located on the passanger side on the front of the intake, but it seems to be coming out the back of a bolt holding a bracket. Any idea how too correct this. Is it a blown intake gasket or does the bolt holding the bracket have a gasket or something that can be replaced. Plus there is no water in the oil, doesn't smoke, or run hot.
PostPosted: Sat Feb 05, 2005 9:49 pm
Sounds like you're talking about the thermostat? There's a bolt holding a bracket that surrounds the upper radiator hose. Yes, there is a gasket there! Just replace your thermostat (while you're in there, they're cheap), it will usually include a gasket with it.
PostPosted: Sun Feb 06, 2005 6:44 pm
Also, it could be something as simple as the hose clamp not being tight enough, might need to replace the clamp. On the neck that the upper radiator hose clamps onto, there is an O-ring there, it could be that too! You should be able to get that from your local auto parts store.
 Post subject: Found the problem
PostPosted: Tue Feb 08, 2005 2:24 pm
I found a hair line crack in my intake manifold. I did a temp. fix with jb weld until I can get another one.
 Post subject: Re: Found the problem
PostPosted: Tue Feb 08, 2005 3:38 pm
Yep, that'll do it too! :lol:
Sounds like a trip to the junk yard is in store for you.
