It is currently Wed Nov 18, 2026 9:31 am
PostPosted: Thu Mar 03, 2005 11:11 am
Accoding to my manual the ECM is located behind the glove box. How do you take a part the glove box? Thanks in advance for any help you can give me. Dan
The manual I have states that the ECM is behind the glove box. how do I remove the glove box to get to the ECM?
PostPosted: Thu Mar 03, 2005 2:10 pm
undo the philips head screws holding the hinge on and remove it then you will see the ECM on a plastic bracket
there ya go
James
PostPosted: Sat Mar 05, 2005 2:57 pm
After finding out now to get to ECM on may 88 Olds piece of cake. There are 7 screws size 9/32 size arouind the glove box liner. You pull out the liner and the ECM is located in the upper right side. To remove ECM you need a 10mm Socket. Part is hard to find called 3 places only one had it. Also they need the 7 digit number on the part to order the right one. Thought I would let everyone know. Thanks, Dan
PostPosted: Sat Mar 05, 2005 3:48 pm
You needed an ECM part number?
1227783 by any chance?
$84.93 for a remanufactured one at GMPartsDirect.com (I am in no way affiliated with them)
