It is currently Wed Nov 18, 2026 9:58 am
flanman
 Posted: Sun Mar 06, 2005 8:29 pm |
Just replaceed the ECM and fuel Injectors. My son went on a short run to the store. He got back in and would not start. When it sits awhile it will start right up. I'm getting really frustrated with it. The starter is less than a year old. Help, Thanks in advance, Dan
_________________ The manual I have states that the ECM is behind the glove box. how do I remove the glove box to get to the ECM?
 Posted: Mon Mar 07, 2005 12:09 am |
how long of a period before the car will start again? Can you think of anything else to tell us?
flanman
 Posted: Tue Mar 08, 2005 10:57 am |
It will start after waiting 10 to 15 minutes. Thanks, Dan
 Posted: Tue Mar 08, 2005 11:14 am |
too little information... need more info!!! does car crank over, but wont fire, or absolutely nothing when you turn the key? does car run rough when it does start, or is everything good?
When you get it started, does it die, or is just when you shut it off that this problem occurs?
So far, there are TOO many things to list that COULD be wrong with your car. We need more information.
It could be the fuel pump, the starter, the coil pack, the ecm... you get the idea...  help us to help you!
flanman
 Posted: Tue Mar 08, 2005 8:01 pm |
The car cranks but acts as if not getting any fuel to start engine. It only does once in awhile. If you wait 10 to 15 minutes it will start. if it sits over that time it will start right up and run great. Fuel pump has a lot of pressure. when we changed injection had a lot of pressure. only when engine is really hot does it act up. Thanks, Dan
 Posted: Wed Mar 09, 2005 9:41 am |
when changing the injectors, did the EGR valve look ok, and got hooked back up correctly?
almost sounds like it could be a spark control problem, just as someone else on this forum was having... This means it could even be as far deep as crank and camshaft sensors... But his wouldnt start if you left it 15 minutes...
Do you know how to check for spark? That would be my first suggestion. Check for spark when the condition exsits. That'll tell us a lot of info.
In the mean time, make sure ALL sensor connections are tight and the wires not chaffed or chewed through. It could be a loose connection that expands when the car gets hot.
 Posted: Wed Mar 09, 2005 9:43 am |
Has anyone got a good way to explain vapour lock, and could this be his problem, after he changed the injectors? ??? (shot in the dark)
 Posted: Wed Mar 09, 2005 9:44 am |
does the ECM give any trouble codes? do you know how to retrieve them?
 Posted: Wed Mar 09, 2005 3:14 pm |
Hi 88delta88, all
Quote: Has anyone got a good way to explain vapor lock, and could this be his problem .............
Excess underhood temperature causes fuel to boil which, turns to vapor which a mechanically driven pump can not move.
Band-aid is to install an electric Fu Pu. It will pump the vapor, then fuel to the carb.
Not an issue with injection systems.
There is alway the possibility a new part (ECM) can be DOA.
Description sounds like a chip acts when it gets too warm.
Since I only know about pre '75s I'm only thinking out loud.
