It is currently Sat Nov 14, 2026 2:16 am
 Post subject: second radiator?
PostPosted: Mon Apr 18, 2005 11:25 am
Images: 11
hi guys
A/C compressor is repaired but we need a new radiator(not the big first radiator the second small radiator for A/C they said)
because we used to other european ccars here i don't know its exactly name(because these cars doesn't have a second radiator
in their A/c isn't it?)... they said its a smaller one that sits near radio but i dont know exactly where it is and i want to
learn just what is its name so we can order a new one :) i thank already for your oncoming replys...
PostPosted: Mon Apr 18, 2005 12:38 pm
Condenser? Or is that the bulb type thing that sits outside the air box?
I know the heater side is called the Heater Core, so maybe the AC Core?
PostPosted: Mon Apr 18, 2005 2:22 pm
That would be the Condenser.
All A/C systems have a condenser, it's what extracts the heat from the system.
PostPosted: Mon Apr 18, 2005 6:36 pm
The air conditioning system has two radiator-like parts. one is the condenser, which is usually mounted in front of your engine's radiator (behind the grill) and the other is the evaporator, which is usually under the dashboard of the car.
If they said it's near your radio, then they are probably talking about the evaporator. I don't know about your car, but I replaced one of these in my truck and the whole dash had to come off.
PostPosted: Fri Apr 22, 2005 4:15 pm
Images: 11
thanks again for your help guys...yes is must be the evaporator..we ordered it from acdelco...its original one is also from acdelco... but still i couldt find the glove compartments lock system :? ... hope i could find one
