It is currently Sat Nov 14, 2026 2:07 am
 Post subject: Car wil not start
PostPosted: Tue Apr 19, 2005 10:18 am
Hi everyone, Well after fixing the things I thought was wrong another problem has come up. For about the last week the car has been harder and harder to start. Finally last night it would not start when my son was coming home from work. It seems the fuel pump works have the smell of gas. Could it possibly be the Ignition module. So far have changed the oxygen sensor, all the fuel injectors, plug wires, and temp sensor. Thanks Dan
The manual I have states that the ECM is behind the glove box. how do I remove the glove box to get to the ECM?
 Post subject: Re: Car wil not start
PostPosted: Wed Apr 20, 2005 12:13 am
Hi flanman, hello all,
........... It seems the fuel pump works have the smell of gas.........
You will never know if it's good or bad until you check it's pressure.
........ Could it possibly be the Ignition module. So far have changed the oxygen sensor, all the fuel injectors, plug wires, and temp sensor ..........
It could also be that one of those parts you replaced was DOA, except none of the above would cause the symtoms you've described.
The question should be: Could the ECM be the problem? To which the answer is no.
From the little information you've given (and have spread through 7 threads) the problem could be any one of about 160 different parts that has failed or worn out.
Were you planning on replacing all 160 (or more) parts one by one until you get lucky?
At your skill level I would pay someone to diagnose it and possibly only replace one more part.
