It is currently Mon Nov 16, 2026 4:49 am
PostPosted: Sun May 08, 2005 10:16 pm
Images: 25
hate to keep buggin everyone, but thought id tell ya.. have another problem with the cutty.. today, me and my family, took my mom out for a dinner.. i decided to drive seperate.. well, i didnt notice it till i was on the way back home.. when ever i get on the brakes, somewhere in the front end, im getting a clunking type of noise.. also does this when i turn.. sounds like the axel.. but im not sure, thats why i made this thread.. like i said, sounds like the axel, or power steering.... n e ideas.. :blowup: :help:
-Joe
Kenwood CD/MP3 player
Rockford fosgate AMP 400 watt
Rockford fosgate Sub 400 watt
Pioneer 3 way 355 watt 6x9's
Pioneer Tweeters
Cobra C/B radio 44 watt
P/A speaker for good times :)
5 foot whip antenna
PostPosted: Mon May 09, 2005 6:27 am
Images: 25
thanx much.. :wave:
-Joe
Pioneer Tweeters
5 foot whip antenna
PostPosted: Mon May 09, 2005 6:58 am
if it clicks ya it`s the cv joint
if it does a consiant sound ya it`s the hub
PostPosted: Mon May 09, 2005 11:58 am
Its your sway bar i believe its called, runs underneath to help stabilize on cornering. Bushing for it is probably gone bad, or some bolts are loose. Try to wiggle it with ur hand from each side should give u a better idea.
PostPosted: Thu May 19, 2005 10:41 am
Well, jack it up. put it on stands, and do some inspection work. Grab the cv shafts, swaybar, try to move the wheels back and forth and figure out what part of the car is loose and clunking. It is almost impossible to diagnose what it is for sure over the web, but I agree that its one of the following; hub, cv shaft, or swaybar, if it has one. That should get you somewhere.
