It is currently Mon Nov 16, 2026 4:12 am
Iroc88
 Posted: Mon May 09, 2005 9:16 am |
I have a 87 Olds' delta 88 Royal brogham, and i started her up today and heard a knocking noise, so i unbolted and took out the oil pan and noticed small ( teeth like ) plastic peices ( ALOT ). So i bolt the pan back up and put it back together with a magnet inside the pan, and i drove the car around and i pulled out the oil pan again and there where ALOT of metal shavings on it stuck onto the magnet.
Anyone know if this could be the oil pump?
Also where is the oil pump located.
Thanks!.
I need a response asap thanks again!.
Also is it worth fixing or should i just sell it?
It has stock trans which was slipping a few months back but i put some lucas oil in it ( stopped ). I replaced the passenger struts and mount ( used ), starter, all brakes, rotor, master cylinder etc. and now i see some rust, the car has 200,xxx kms on it.
I took out the oil pan and unbolted a bearing and the guy told me they were burnt, today. Thanks again!.
 Posted: Thu May 12, 2005 10:48 am |
DEFINATELY the timing gears are wearing out. Soon it will skip a tooth, and possibly damage the valves. CHANGE IT!!! (i know this from experience)
 Posted: Thu May 12, 2005 8:38 pm |
Cutlass95Ciera wrote: hum....the first post i see is Brando's. For some reason I dont see the orgional post
lol...that was when the time got screwed up...the original post is after mine.
