It is currently Mon Nov 16, 2026 4:26 am
 Page 1 of 1 [ 7 posts ]
PostPosted: Wed May 11, 2005 3:55 pm
Images: 9
I got a Check Engine light today on my way to work in my 1987 442, so when I got home I checked it out and got trouble code 32. My CSM tells me that means the Barometric Pressure Sensor got caught sending bad info to the ECM. When I reset the Check Engine light and restarted the car and ran it for a while the light did not come back on. Perhaps it was just a fluke, but I am wondering:
1. Will it damage anything to run with a bad Baro Sensor?
2. It looks like (according to the CSM) that the Baro Sensor is under/behind the glove box. Has anyone ever replaced one? Is that where it is? Is it easy to get to? What does one cost?
Thanks for any help.
Alan
"'Cause tramps like us, baby we were born to run" - Springsteen
PostPosted: Sat May 14, 2005 11:59 pm
Alright, looked it up:
Code 32 means the Baro Sensor Voltage Too Low.
It could have very well just have been a fluke....otherwise you would notice it running differently, is it?
Have a voltage meter on hand and use this and this to diagnose your problem.
As for location, it says it could either be in the engine compartment or strapped to the ECM harness under the dash panel.
PostPosted: Sun May 15, 2005 7:11 am
I'm wondering what that Baro sensor does? It sounds like it's there to measure the barometric pressure... but for what? I could see if it was injected but how can a computer control a Q-jet? I was kinda interested because I was helping my younger brother work on his 88 Monte Carlo SS(which probably has alot in common with your 442 mechanicaly) and it was throwing a code 32, which the haynes manual said was a "differential pressure sensor" are these related?
PostPosted: Sun May 15, 2005 12:35 pm
yes, Baro sensor equals Barometric Pressure Sensor...hence the title of this topic :lol:
Different altitude levels equals different air densities, which means the carburetor needs to be tuned differently to acommodate these changes in air.
Pretty sure the "differential pressure sensor" is the same thing.
PostPosted: Sun May 15, 2005 12:49 pm
so the computer actually changes the fuel/air mix? ...on a carb?? :huh:
I thought it would just be able to play around with things like the spark / timing to compensate for altitude changes.
PostPosted: Sun May 15, 2005 1:37 pm
Well, it appears as if it actually controls the amount of vacuum to the manifold....
PostPosted: Sun May 15, 2005 7:07 pm
Hello all,
As usual I will limit my comments to the information I know to be fact.
so the computer actually changes the fuel/air mix? ...on a carb? ...........
Yes.
.......... it actually controls the amount of vacuum to the manifold ...........
No. Throttle blade opening controls manifold vacuum.
