It is currently Mon Nov 16, 2026 5:14 am
 Page 1 of 3 [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: Car wont start
PostPosted: Thu May 12, 2005 1:23 pm
This morning I went to go start the Olds so that I could go to school. It started right up and ran fro about 2 min. or so. Then I just tapped the gas to calm the idle a little before putting it into drive and going. But as soon as a tapped the gas, the engine sputtered and died. Now it wont even start (the starter is getting the engine rotating but I dont think theres any spark) what the hell caused this?
PostPosted: Thu May 12, 2005 2:46 pm
id doesnt start even when u turn the key with the gas down a bit? Seems kinda odd. Did it start after you let it sit for a while? Possibly timing chain, but i dont know for sure. Do u hear ur fuel pump hum when u turn the key to the on position? Check fuses.
PostPosted: Thu May 12, 2005 5:24 pm
maybe it flooded itself, after running with the choke on, or the butterflies are gummed shut? That happened to a friends vehicle once. If it starts later on today, you might benefit from a good throttle body cleaning...
PostPosted: Thu May 12, 2005 6:57 pm
Is that TBI or carburated?
I seem to remember you saying it was TBI... in which case it's unlikely that it's flooded
PostPosted: Thu May 12, 2005 7:37 pm
Well I decided to get it towed to the corner shop for some fixen. Its TBI, and I can hear the fuel pump. I have had problems with it flooding before but it seems to be acting different now, after it not starting today I had to give in and let it go to the shop...
PostPosted: Fri May 13, 2005 5:38 pm
Well the shop called earlier and said that the car has no spark, maybe a coil pack or something.
PostPosted: Fri May 13, 2005 9:27 pm
Hi 85cieraholiday, hello all
.......... the car has no spark ..........
One of my favorite subjects:
Looks like you were more interested in fixing it than talking about it.
I wonder how many good fuel system parts you would have had to replace before you found the ignition problem. :lol:
Seriously, glad to see you found the answer.
PostPosted: Sat May 14, 2005 6:52 am
HEI distributor? you probably need a new module....that is your spark.
When they go they just go. Car will crank but module needed to produce spark.
PostPosted: Sat May 14, 2005 7:03 am
Hi all
HEI distributor? ............. When they go they just go ...........
Points will usually give advance warning. :lol:
PostPosted: Sat May 14, 2005 11:54 am
Well my car doesnt have points, but as I always tell my mechanics I dont care what it cost or how long its down there I just want my car back. This is the 5th time since Oct. that its been down there (for all different reasons) and its the 2nd time (of the 5) that it was towed.
"Looks like you were more interested in fixing it than talking about it."
Yeah as my firends/ family/ autoshop class/ mechanics know that when it comes to my Olds there is no fooling around, I 100% baby the car (never had it past 70, cruise is set at 55, never even thought of racing or doing anything like that) So when I find that my car needs something, there are no questions asked just fix it.
PostPosted: Sat May 14, 2005 7:32 pm
Hi all
module does not give a warning when it goes out. It can shut off when no good at any time without any warning.
PostPosted: Sat May 14, 2005 10:42 pm
That would explain why it just died.
PostPosted: Sat May 14, 2005 11:16 pm
I have been driving for nearly 4o years and have experienced this several times over the past 20 years. My 76 Buick Century custom wagon sitting at a long light on a day that reached 100 degree's just shut off. I tried to start it and it cranked but no spark. I had sat at the light for over 5 minutes. Though the engine did not overheat sure enough the module went out. Then 3 years ago at 4:30 in the morning on my way to work cruising down the hiway doing 60mph and sure enough, engine just turned off. Had car towed home. Went to auto parts store picked up another module, installed and fired right up. My 66 442 runs a 9000 comp. It has a more expensive module. Got on the hiway, got on it a little, 2 miles up the road stopped at the market. Came out, wouldn't start. Pulled and replaced the module started fine and 2 months later drove that car 7000 miles across the southern states to NE NJ and back home across the northern states and no problem. No a module gives no warning when it goes out. It is the electrical relay source. It sits under the rotor. There are NO points with electronic ignition so points are not the problem and a module can blow out letting the car warm up, stalling and trying to re-start. In the states stock one will run between $45.00 and $65.00. My 442, they are $125.00. Be happy if that is the problem and you don't have to worry blowing those out.
PostPosted: Sun May 15, 2005 3:56 am
Hi yogis442, all
Sounds like points might be better. Less expense and no surprises. :lol:
What's a 9000 Comp?
PostPosted: Sun May 15, 2005 4:19 am
Hi 85cieraholiday, all
........ my car doesn't have points .........
Probably not practical to convert it to points. :lol:
............ when I find that my car needs something, there are no questions asked just fix it.
Good thinking.
