It is currently Mon Nov 16, 2026 5:04 am
 Post subject: Sagging Headliner
PostPosted: Thu May 19, 2005 9:19 pm
I noticed today that my headliner is sagging in two spots i was suprised. Looks like crap, i need to get it fixed asap. I was reading up on it and there are some quick fixes, but the proper way to do it and not have it happen again is to take the whole headliner unit out as one piece and redo it.
Anyone had this problem and get it fixed? I wouldnt mined if a quick fix could hold it up again for another 5 years, cause i heard headliner jobs can be costly.
 Post subject: Re: Sagging Headliner
PostPosted: Fri May 20, 2005 12:52 am
Hi speedy266, hello all
......... i heard headliner jobs can be costly.
My 307 came glued in, Local shop installed a new one for $90
The early stuff you just buy the liner, and the install is a snap.
PostPosted: Fri May 20, 2005 3:05 pm
My entire headliner was falling down, I used some 3M spray on adhesive (sp?)It worked real well.
PostPosted: Fri May 20, 2005 3:14 pm
Images: 9
I used a similar product but mine came down at the back. It was probably due to the fact that I didn't do the best job the first time since I was running low. This time I made sure I did it properly, and it's looking good again.
PostPosted: Sat May 21, 2005 12:04 am
Hm i think i'll do that thanks.
