I have a 95 Achieva whose both front control arms might need to be replaced. Options that two different mechanics gave me were to:
1 - replace both at $197 for each part + labor
2 - replace just bushings at a whole lot less
One mechanic says to just do the bushings. The other says the bushings will not work for long at all and I should do the full replacement. Has anyone replaced only the bushings in the past and what was the outcome?
I like to repair things right the first time even if I cannot fully afford it at this time instead of having to do it again in a month. I am torn. Please help me decide.
Thanks a bunch.
Posted: Tue May 24, 2005 12:22 pm
Joined: Fri Jun 06, 2003 3:58 pm Posts: 3166 Images:29 Location: Michigan, USA
Sounds like the first guy is taking you for a ride. Only reason to replace the who control arm is if it is bent...and if it isn't, just have the other guy do the bushings.
The way i see it Control arms are like your engine, bushings is like the oil. You can replace the bushing several times before its time to replace the control arm. If your control arms are fine which they probably are just go with bushings.
