It is currently Wed Nov 11, 2026 12:07 am
 Page 1 of 1 [ 6 posts ]
 Post subject: code 32
PostPosted: Wed Jun 01, 2005 9:22 am
:( how do i trouble shoot to fine the problem EGR system,,thanks bob
PostPosted: Wed Jun 01, 2005 12:49 pm
According to the service manual,
Code 32 will be set if the EGR diagnostic vacuum switch sense vacuum at idle, of if it does not sense vacuum in gear with moderate to heavy engine load, but less than WOT.
The EGR valve is energized based on the following inputs:
-Engine running above idle, but less than WOT
-Code 33 or 34 not present
-Engine coolant temperature 42.5C(108F) or above
-Transmission in gear
check all vacume lines
PostPosted: Fri Jun 03, 2005 9:22 am
thanks for your help.....found that the vacume solnod needed to be replaced problem fix.......one more thing when i start car in the morning letting it warm up...the check eng.light comes on....when i drive off it goes out...and never comes on again,,only in the morning,,,is this normal??????thanks again
PostPosted: Mon Jun 06, 2005 10:14 am
TPS sensor can cause that problem. If the voltage it too low at idle, when your foot is off the pedal, then the computer will trip into open loop and give you a check engine light. Could be the O2 sensor aswell, when the car is cold... Could be a whole lot of things, best thing to do is to read that error code, or codes, and then post back here.
PostPosted: Tue Jun 07, 2005 2:09 am
hi thanks for repley....code 24 is found vss....had new speedo cable replaced.....when i start car in morning,,and put in drive no light..when i let it warm up i get light....thanks for your help
PostPosted: Fri Jun 10, 2005 3:21 pm
you found a new code - 24? Or did that one already exist? You are having problems now, when the car gets warm? Is this a different problem?
