It is currently Thu Nov 12, 2026 12:07 am
87Delta
 Posted: Thu Jun 09, 2005 4:51 pm |
Hello all! Today just having the car idling, listening to the radio (fairly loud, heh) the car all of a sudden the engine vibrated violently and shut off. Tried to save it by jabbin the throttle but nothing, she just died. After cussin and hollerin at it I tried crankin her. It would crank but no fire. Then the battery went dead after 20 seconds. It would crank really slow. I was like ok, maybe she just needs to cool down. Tried 5 minutes later, it cranked really slow. Then all of a sudden it cranked at normal speed. Still no fire. After cranking it at its slow speed, letting off the key, I can hear some kinda pump making a weird gargling noise. I was gonna throw the battery on the charger, but a violent thunderstorm went through. I might try later. Right now im kinda thinking it's the fuel pump or filter since it won't get and fire. Still, id like to hear some opinions. Hopefully it's not the fuel pump cuz thats a bitch to do in a 1987 Delta 88. Thanks for taking your time to read this. (BTW the check engine light came back on a week after the O2 sensor was replaced, wtf!?)
-Adam
abbike18
 Posted: Thu Jun 09, 2005 8:51 pm |
sounds to me like an issue with your idle air control valve (IAC). Its the little solenoid on your throttle bodt that controls airflow during startup and idle. It is fairly easy to replace and can be bought at any local autoparts store. One question to make sure it is the IAC: when the car is running and you are hittingthe gas pedal to keep it running, does the car run smooth then and at what rpm are you at? if the car is running rough at normal operating rpms then it is something else. If it runs smooth at normal operating rpms then it is definitly your IAC.
_________________ 1986 Oldsmobile 98 Regency Broughm
1991 3.8L 231cid V6
custom cold air intake
strut bar
 Posted: Fri Jun 10, 2005 3:02 pm |
TIMING CHAIN!!! change your oil, and see if plastic and/or aluminum peices and shavings drain out of the oil pan. If this is the case, have your timing chain changed before you run the engine again.
If the chain slipps and you continue to try turning it over, you will BEND and break valves, and that would likely call for a new motor, or major overhaul anyways. So, for the few bucks it costs to change oil, try it first.
After that, and no dice, post back, and maybe you'll have to check out your ignition system.
 Posted: Fri Jun 10, 2005 9:26 pm |
It could be that some of the nylon teeth have come off and thats what caused it to stall. Those teeth can plug your oil sump, and if they do, its major engine problems. It is definintely worth checking out IMO. I dont thing a fuel problem would cause that sort of vibration that you described. I would think that it would chug like it was out of gas. Maybe the pushrod or the lever on the fuel pump is bent or broken... Just throwing that out there, idk if that could actually happen.
 Posted: Sat Jun 11, 2005 10:26 pm |
Hi 87Delta, hello all,
Quote: ......... Soemthing with the mass airflow sensor. A new one is like $300. ...........(
There is some good information and some not so good information on the subject, Here.
I'm waiting for one individual to correct his last post, then I'll clean up the rest of his mess and you might learn something that will change your mind.
I like your sig, it mirrors my philosophy. I know who I am and what I've got, and I have no need to prove anything to anyone.
 Posted: Wed Jun 15, 2005 7:47 pm |
HI 87Delta, All,
Quote: Ok, it may be a stupid question ......... There are no stupid questions. Unfortunately, there are a lot of stupid answers and statements. Quote: ........ one of them had separated where the wire and the metal piece that goes on the spark plug. Might have saved yourself 300 bux.  Quote: I presume this is why it seemed to run outta time. Differing descriptions of the same symptoms are the reason I normally do not get involved in diagnosis over the internet. A "miss" caused by a faulty plug wire cannot make an engine sound "out of time", and I don't believe your problem to be timing related. As we now know, your description was inaccurate and led to those answers that were unrelated to your problem, now we can continue. abbike18 wrote: sounds to me like an issue with your idle air control valve (IAC). Its the little solenoid on your throttle body that controls airflow during startup and idle. It is fairly easy to replace and can be bought at any local autoparts store. One question to make sure it is the IAC: when the car is running and you are hittingthe gas pedal to keep it running, does the car run smooth then and at what rpm are you at? if the car is running rough at normal operating rpms then it is something else. If it runs smooth at normal operating rpms then it is definitly your IAC. A tach is not needed to perform the above test. Idle, off idle, cruise, accelerate, or WOT can be used in place of RPM numbers. The test is free, quick and simple. It should be your main focus, since it actually relates to your problem. Quote: ........I am thinking it has clogged injectors as well.......
Please explain why you think so. Your answer could lead us to your solution.
When you post back, we can continue.
87Delta
 Posted: Wed Jun 15, 2005 7:53 pm |
Quote: What was the result when you tried abbike18s suggestion. From what was happening with the car, it wasn't the IAC. When it did run it would be fine, smooth power throughout all the throttle. Quote: ........I am thinking it has clogged injectors as well....... Quote: Please explain why you think so. Your answer could lead us to your solution.
When it did run, before giving me starting problems, it would seem to hesitate and sometimes bog down when stompping on the gas to pass a car on the highway. It may just be in my head though.
When it was runing and about to shut off, it was more like a missfire then it being out of time, I really didn't have words for it, thanks for clearing that up. Sorry for all the confusion. Should of bought a moped to get around town, heh.
 Posted: Wed Jun 15, 2005 7:58 pm |
The spark plug is a great way to diagnose engine problems....have a look at this:
http://www.dansmc.com/Spark_Plugs/Spark ... talog.html
Can tell you if your running lean...clogged injector/s...could also be fuel pump, in which you would need to measure fuel pressure with a guage if all the spark plugs look lean.
If you press the gas pedal and it hesitates, that could be the TPS sensor or throttle cable.
 Posted: Wed Jun 15, 2005 8:46 pm |
Hi All
87Delta wrote: From what was happening with the car, it wasn't the IAC. When it did run it would be fine, smooth power throughout all the throttle. 87Delta wrote: Quote: ........I am thinking it has clogged injectors as well....... Quote: Please explain why you think so. When it did run, before giving me starting problems, it would seem to hesitate and sometimes bog down when stomping on the gas to pass a car on the highway. It may just be in my head though.
87Delta: Asking questions is qood; it's how we all learn.
All: Above is a good example of why I do not normally get involved with internet diagnosis.
I'm outta here.
 Posted: Wed Jun 15, 2005 10:11 pm |
Checking the fuel filter or just replacing it would also be a good start. Also doing a fuel pump volume test would help to determine if it is fuel related. Also check your lines and hoses for cracks. That would be a good start in my opinion.
