It is currently Mon Nov 09, 2026 10:55 pm
 Post subject: Delta 88....fuel pump?
PostPosted: Sun Jun 26, 2005 4:59 pm
Okay...so I was running the delta today...and I started to hear this sound....
It's hard to explain....but the fuel pressure sounded like it would stop when it made this sound... :-s
I am guessing that would be the fuel pump...the fuel filter and lines were already changed...as well as the tank, I guess the pump was never changed though. :doh:
PostPosted: Mon Jun 27, 2005 8:55 am
dont worry if it is the pump brando, they're easy to change.
The biggest thing you need to do before you drop the tank - get all the fuel out.
Unhook the sending line just before the fuel filter, and run the pump till fills up a gerry can. You can make the pump run from the relay by your horn. (Check your all-data book!)
After that, you just unscrew one bolt from each metal strap, and down it comes! Changing the pump itself is a snap, but dont run the pump dry, get some fuel in there before you put power on it. :-) have fun!
Users browsing this forum: No registered users and 20 guests
