It is currently Mon Nov 09, 2026 10:47 pm
 Page 1 of 1 [ 9 posts ]
PostPosted: Sun Jun 26, 2005 5:30 pm
Images: 11
hi guys i need your help about our vin code...
because i am newbie in these issues i couldnt dig out all the letters in the code... i learned some of them but not all.. and i wonder if i can figure out if we have FE3 suspension or not from the vin code?
here is our code;
1G3HY51C1\H331452
in tenth digit ( \ )this sign has this symbol( _ )under it..is it something special or not i read out in some sites that its the legalty of vin code or something?... .i know the code C we have 3800 but i want to learn more...if you can help me i would be happy 8)
PostPosted: Sun Jun 26, 2005 5:57 pm
I have just the info you need...please hold... :lol:
PostPosted: Sun Jun 26, 2005 6:03 pm
HERE you go.
That 10th digit is an L, designating that it is a 1990.
Unfortunately, you cannot know if you have FE3 from the VIN, you need the build sheet.
PostPosted: Sun Jun 26, 2005 6:15 pm
Images: 11
hey brando thank you very much.... :)
in this site i like the way olds owners help each other
pitly we don't have any buildt sheet :(
is there any way to try to understand by looking in lower parts of vehicle by lie down to cars under :?
and one question more i discovered when we turning steering wheel to limits like when making parking to a small area to fit the car i heard a click sound from in front of the vehicle... but that doesnt make sound when the steering is in not limits...when we turn it to limits its always clicks from frontside... or maybe it can be something else?
PostPosted: Sun Jun 26, 2005 6:19 pm
Well....there's not really much to see from underneath....the steering was tighter, the gear ratio inside the rack and pinion was changed...but that's on the inside...really no external differences.
As for the clicking noise....if you turn it too far one way and it does that....that's normal.
PostPosted: Sun Jun 26, 2005 8:10 pm
You cant find the FE3 option in the vin code, look in your trunk under the mat for a sticker that says parts indentification codes and FE3 will be there if your car has it.
PostPosted: Sun Jun 26, 2005 8:15 pm
under the mat? I've never seen a sticker in there.... :-k
PostPosted: Mon Jun 27, 2005 8:51 am
check and see... I think FE3's had REAR SWAY BARS. Dont quote me, on that, but I know they at least had HEAVIER sway bars in the front.
You likely would have had a badge on the rear trunk lid, unless the car has been painted.
PostPosted: Mon Jun 27, 2005 11:50 am
Thats where they are on many GM cars of this time period, they also can be in the glove box, on the inside of the trunk lid, and in the center console (Corvette). The stickers were used to replace build sheets (broadcast sheets for those Chrysler owner out there). Build sheets were phased out and by 1990 they were no longer used. Nearly all the info on my build sheet is also found on this sticker.
Users browsing this forum: No registered users and 26 guests
