None of the lights above where the speedometer is work. Do you know what could cause that? All of my fuses work just fine, they've all been checked. The main reason I need the lights to work is so I can read the codes from the ECM. Is there a way to read the codes anyway? I've read that in some cars you can hook up a light to the ODB connector. Thanks.
