It is currently Tue Nov 10, 2026 4:46 am
 Posted: Thu Jul 21, 2005 10:29 am |
1987 olds wrote: The only thing i can think of is to start replacing sensors until i get lucky but what one first?
Very bad idea....costs a lot of money and might not even be a sensor.
Have you checked fuel pressure? Could be the fuel pump failing....like mine.
Check the spark plugs, what do they look like?
Could be a vacuum leak...spray some carb cleaner with the engine running around the vacuum lines...see if the idle changes.
1987 olds
 Posted: Thu Jul 21, 2005 6:15 pm |
Yes in my other post "stalling" i listed things that have been done ill list them again..these parts are brand new...fuel filter, fuel pump, crank sensor, iac motor, idle sensor,wires, plugs..i ran injector cleaner through it a few times, the car runs fantastic on highway with no missing at all its when i come to a stop it will stall but not always..had it to different garages that checked vaccum leaks etc and ran a diagnostic on it and everything comes up perfect..really confused here and that is why im wondering if any of these sensors ie maf, tpc, ignition module are known for causing this sort of problem without tripping a code?
 Posted: Fri Jul 22, 2005 9:20 am |
something to check:
take your multimeter, and ohm out a little sensor inside your airbox. This is the intake air temp sensor, and if the sensor fails, it can cause stupid stalls and idle problems. If you get a value (dont ask what the specific resistance should be...) with the multimeter, the sensor is likely good, but its a good idea to check it first. Just unplug the weather connector, and measure from one conductor to the other on the sensor.
MAF's can cause this problem also, I have had both scenarios with my 3.8L. In all reality, I dont know how to properly test a mass airflow sensor without special equipment to measure it from idle conditions to wide open throttle.
From experience though, while the car is idling, go under the hood and grab the MAF, and move it around slightly, so the air flow changes direction flowing over the maf (I am assuming you have the 3.8L, not the 3800 engine). Doing this might make the air pass over a spot of the MAF that is dirty or faulty, and in turn cause the engine to run differently. If you can re-create your stalling problem under the hood by doing this, I'd say its the MAF. This is how I pinpointed my MAF sensor being faulty.
Some one else want to step up with more detailed diagnostics for MAF's?
