It is currently Sun Nov 08, 2026 1:02 am
 Page 1 of 1 [ 11 posts ]
 Post subject: Knocking at startup
PostPosted: Mon Aug 08, 2005 9:20 pm
I currently drive a 91 Olds Toronado Trofeo with a 3.8L engine and when i start my car when the motors cold, theres a terrible knocking in the motor that lasts for a couple seconds. The knocking is so great that it makes the whole car shake. When i start up and look under the hood it sounds like its coming from the bottom part of the motor near the exhaust manifold. Does anyone have any clue what it could be? Thanks!
PostPosted: Mon Aug 08, 2005 9:56 pm
Images: 25
mine does the same, its a Lifter.. altho mine does not shake, your's still sounds like it could be a lifter..
-Joe
Kenwood CD/MP3 player
Rockford fosgate AMP 400 watt
Rockford fosgate Sub 400 watt
Pioneer 3 way 355 watt 6x9's
Pioneer Tweeters
Cobra C/B radio 44 watt
P/A speaker for good times :)
5 foot whip antenna
PostPosted: Mon Aug 08, 2005 10:34 pm
A lifter would be more of a tick, and the noise would be generated in the top end of the engine, almost as if it were coming out of the valve cover. I would check your motor mounts. Is this knock metallic, or is it more of a clunk of something big? I hate to answer a question with a question, but there are many possibilities.
PostPosted: Mon Aug 08, 2005 11:08 pm
It sounds more like a clunking sound, and i also noticed sometimes if i give a little gas in neutral and back off it, it will make a clunking noise
PostPosted: Mon Aug 08, 2005 11:11 pm
I think it might be a motor mount, but without hearing it, its tough to tell. You might want to get a long screwdriver and have some one rev the engine while you plave the tip on various non rotating parts with your ear up to the end of it. Try the trans bell housing, and watch the engine for excess movement while revving. Hope that helps
PostPosted: Tue Aug 09, 2005 7:15 pm
Images: 25
sorry for giving you the wrong answer, and thanx andrew for clearing that up for me.
-Joe
Pioneer Tweeters
5 foot whip antenna
PostPosted: Tue Aug 09, 2005 7:27 pm
No problem, since the board doesnt have sound bytes, its hard to diagnose when you cant hear it. Could be anything from a lifter to a rod. But any answer is a mere guess until the actual sound is heard.
PostPosted: Tue Aug 09, 2005 7:30 pm
Images: 25
since its hard for us to tell what it is, id just take it in..
-Joe
Pioneer Tweeters
5 foot whip antenna
PostPosted: Thu Sep 29, 2005 9:50 am
Images: 1
or its nothing...it could just be an oil pump problem...
PostPosted: Thu Sep 29, 2005 11:54 am
But an oil pump problem is SOMETHING. I would say that if your engine knowck audibly at startup, and if that knock is so great that it makes the entire car shake, then it is most definitely SOMETHING.
PostPosted: Thu Sep 29, 2005 12:03 pm
my friends vehicle had a problem with the oil pump. He knew about the oil pump problem, and chose to ignore it... The car self destructed when the pump finally siezed...
